Battery Just Blew Up
Old Oct 23, 2015 | 03:25 PM
  #41
Gale Banks 80''s Avatar
Gale Banks 80'
As a Teenager in gas engines class we rebuilt a WWII Dodge Power Wagon Flathead Engine. When we went to start it the 6 Volt Battery was low so why not just jump start it with a 12V right ? When we hit the Starter the Battery Blew and we all jumped back. Them we walked up to see what happened and saw the Top of the battery was gone. About that time the top of the Battery landed next to Us. I have always wondered how High up that Top got !!!
Old Oct 23, 2015 | 03:56 PM
  #42
vettefred's Avatar
vettefred
Skip Shift
I have switched from HF to Battery Tender Jr. They seem to be working OK as I have had them on all my collector vehicles for a couple of years.
Fred
Old Oct 23, 2015 | 04:46 PM
  #43
hugie82's Avatar
hugie82
I'm 47 also and I've only seen 2 blow and that was back in the 80s. Both where battery's that had been relocated into the trunk. I've been using Optimum battery's without any issues. They are designed to take a hi amp charge.
For most of my maintained batteries I have my battery tender tied into my garage lights. So it's only on when I'm in the garage. Usually comes out to 3 to 20 hours a week but I've never had a dead battery, nor have I had any over charge, boil of their water or have a battery blow.
Old Oct 23, 2015 | 04:56 PM
  #44
Paul Van Nest's Avatar
Paul Van Nest
Banned Scam/Spammer
From: Simi Valley Ca. all the way to Shell Knob, Mo. A piece of heaven.
Originally Posted by zwede
The battery was boiling, producing hydrogen gas that ignited.
So the possibilities I see are either the battery had a bad cell causing the tender to try to charge it and boiling the remaining cells, or the tender is bad.
I have a CTEK tender and it does detect a bad battery and stops charging.
This.
I had a Harbor Freight tender as well connected to a battery on my Dodge. I didn't know it and it too had a bad cell. It was one heck of an explosion when it went. Moral to the story get a good tender that can detect issues.
Old Oct 23, 2015 | 11:59 PM
  #45
BlackC3vette's Avatar
BlackC3vette
Originally Posted by Paul Van Nest
This.
Old Oct 24, 2015 | 10:22 AM
  #46
midigike's Avatar
midigike
As I am approaching the season where I put her to bed for 5-6 months, I always pull the battery out of the car for this very reason. I didn't do it the first year I owned the car, in the spring when I took the layers of covers off, the interior had a very metallic smell, battery hydrogen. I had mentioned that to guy I worked with who has several cars and he told me to never ever do that again. So I always pull the negative terminal off in the summer between rides and always pull the battery out when I store it.
If I'm not mistaken the original batteries were vented and a hose went out through the battery box floor
Old Oct 25, 2015 | 09:56 PM
  #47
Brass Pass's Avatar
Brass Pass
I was out for a test cruise this afternoon in the C3 and as I was getting onto the freeway I heard a loud hissing sound behind me. It sounded like air out of an air compressor.
I pulled over thinking my rear tire had blown. Tire was ok, it was the battery. After about 5 seconds it quit, but was hot to the touch. I never shut the car off and everything seemed alright so I drove home.
I had noticed earlier that my ammeter was pegged at +40 instead of the normal 0 and then 0 to +40 when the radiator fans kicked on. The battery was hot to the touch for a quite a while after getting home. I guess it's time for a new battery.
The battery is an Optima yellow top that I have on a C-Tek 7200 charger almost all of the time on the AGM setting. Time to start a new battery maintenance program after reading some of these posts.
Glad to hear you're ok OP.
Old Oct 25, 2015 | 10:37 PM
  #48
Gale Banks 80'
Sounds to me You had some sort of over charging issue going on. It might of fried the Battery or may not.
Old Oct 25, 2015 | 10:50 PM
  #49
Brass Pass's Avatar
Brass Pass
Hopefully, it was just the battery going bad and not the voltage regulator in the alternator. I really don't want to spend time having to hunt down an overcharging issue.
You may be right though. Something else could be going on. I'll find out when I get a new battery. I just removed the battery from the car and it's been 2.5 to 3 hours since I parked. It is still hot to the touch. I left it outside away from the house just in case.
Old Oct 26, 2015 | 03:24 PM
  #50
Tampa Jerry's Avatar
Tampa Jerry
Default Overcharging
You may want to put a meter on the battery and the alt.with the car running. If you are getting more than 14.6 volts, your alt. may need to be rebuilt. If it is any early C-3, you may have a problem with your voltage regulator. Both can overcharge a battery. Jerry
Old Oct 26, 2015 | 06:09 PM
  #51
Brass Pass's Avatar
Brass Pass
Yes, I also have a feeling the voltage regulator may have gone south on me. I'm going to buy a new battery just as a precaution since it was hot to the touch for many hours after I took it out of the car.
Even if the voltage regulator is the culprit I don't feel as though the battery I removed couldn't have escaped some type of thermal damage. I've had that battery since 2008, so it is probably time for a new yellow top anyways.
Old Oct 27, 2015 | 12:02 AM
  #52
Brass Pass's Avatar
Brass Pass
Ok, I just installed a new Optima Yellow Top. Voltage reading was 12.6 before starting the car.
After starting the ammeter moved to the first unmarked line for a while then went back to the 0 mark. Before with the old battery it was hitting the +40 line and has been doing this for quite some time. I thought it was normal for it to do this under load.
With the radiator fans and A/C on and charging it goes to the first unmarked line and voltage at the battery reads 14.2 volts. I think my alternator is ok.
I have been having starting problems and I think the battery was the problem all along. I've checked every area I could find for vacuum leaks, changed plugs, wires, pertronix flamethrower ignition module, distributor cap, rotor and the ignition switch last month in order to get it to start the first time every time again and still had problems.
After the battery change it fires like it used to first time every time. Close call yesterday, but a blessing in disguise. I consider it $180.00 well spent.
