Speedometer light and gauge lights out
Old Dec 28, 2015 | 02:33 AM
socal79's Avatar
socal79
Default Speedometer light and gauge lights out
so after getting my 79 running again I noticed only the tachometer and gear selector light lights up. the speedo and gauges are dark. only the right turn signal indicator works. the headlight switch works to turn on the headlights and dim the two functioning lights. since not all of the lights are out, what can be the problem? my research is pointing towards the circuit board.
Old Dec 28, 2015 | 02:41 PM
7T1vette's Avatar
7T1vette
Bulbs burnt out, bad grounding connections/wires, defective circuit board (if your model has one).
To check if grounding is a problem, you can run a jumper wire (with alligator clips, perhaps) from a known good point of chassis ground (or fuse block ground) to metal part where bulb socket is installed. When light power is applied. Light should work, if grounding is the problem and bulb/socket is good.
Old Dec 30, 2015 | 07:08 AM
cooper9811's Avatar
cooper9811
I would start with grounding and connections around the fuse box- had a similar (intermittent) issue with my 79, and had to clean and tighten up connections around where my fuse panel mounts to the firewall.
Old Dec 30, 2015 | 06:41 PM
DUB's Avatar
DUB
IF you have SOME gauge lights that work and others that do not...that is telling me that the circuit is working...and YES...you either need to inspect the printed circuit board for the speedo/tach etc....or you have bad bulbs.
FOR WHAT IT IS WORTH....
if you go to remove your speed/tach cluster...it is wise to drop the steering column a bit so it will come out a little bit easier.....BUT BE CAREFUL.....because the bottom plate that is welded to the mast jacket of the steering column itself....where you remove the 2 bolts under the column...this wide plate can damage your dash panel if you are not careful. And it is also wise to carefully loosen the two nuts at the firewall where the steering column gets secured to it also....so the column can lower a bit.
DUB
To Speedometer light and gauge lights out
