Decided to start a new thread on my engine overhaul.
Started with cam swap and developed to a complete overhaul with a 468 bore and a new crankshaft.
My engine builder told me that my crank was shot...to much axialplay.
So... it will be a completly new engine on the inside.
Straubtech has provided me with all parts and it will be a piece of art when it is finished.
Downside is i could just as well bought a new ZZ502 instead......
But now i will have a beatiful 468 and it will perform just as well thanks to Chris!
I know the feeling I got a beautiful 355 sbc all the bells n whistles chrome and aluminum everything, electric wp, at the end when I did the math I could of done an ls swap for just a tad less but or just threw in the extra 500 and built a stroker but at the time I didn't want anything to radical as I had just gotten my license back and didn't want trouble with the police now that I barely drive it, it would have been a better option as its a cruiser and not a dd anymore but I love how it came out and still fun toy now though is time to save up for a small supercharger.
A bit more info on my Engine build.
Scat 4340 crank.
Mahle pistons.
Eagle rods.
Morel lifters.
Comp gold rockers.
Brown Brothers springs.
Straub cam, 229/241@050, .600/.620.
New oilpump, quickfuel mechanical fuelpump, MSD probillet distributor, new harmonic balancer..+.and more...
Only stock items is engineblock, heads and valves...
All parts from Straubtech, 5400 USD+ tax and customs.
And then some shop costs....
A lot of money, but a new ZZ502 is 13000USD in Sweden...
This engine will beat a ZZ502... and the sound, do i have to say more..........
Scat 4340 crank.
Mahle pistons.
Eagle rods.
Morel lifters.
Comp gold rockers.
You will be much happier with those pieces than a ZZ502.....
468 Project update!
After a lot of issues and misshaps i have begun to build my engine.
Heads are rebuilt with vitonseals and new springs ready for the Straubcam.
Pistonrings filed and assembled on pistons with eagle rods.
Crank, pistons and rods are balanced.
The Scat crank was horrible out of balance!!!
Engineblock washed in acidbath and new bearings for cam, crank and rods installed.
This is when the fun begins, assembly!
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's odd a brand new 4340 Scat crank way out of balance, these cranks should be right on the money for the price you pay. Where did you get the crank, some companies sell "blemished" or out spec cranks but they usually do tell you what is wrong with it.
Like for instance they will say the crank had to be turned 10thou. Usually to get tremove a problem with one or two main journals. Still a perfectly good crank you just use thicker bearings.
Have building the engine it is a great learning experience and a lot of fun
Bought the crank from Chris Straub and everything else to my engine.
Had to take out 70grams on one side and 60grams on the other.
Guy who balanced it said it was one of the worst unbalanced cranks he had ever done.....
OK, I understand that you bought new ones.... but are they counterweighted (454) or a neutral balanced (427)?
Originally an OEM 454 BBC was designed for external balance.... Both FW and damper will have a counterweight.... this was so GM could make them easier to balance without having to re-design the crankshaft forgings to add more mass to the counterweights. The after market SCAT crank has better designed counterweights and depending on the weight of the other rotating assy parts may have been able to be balanced with a 427 style neutral balancer and FW.
Also modern aftermarket connecting rods and pistons are much lighter weight than the OEM pieces.... which mean drilling the counterweights.
These things are what most likely attributed to your new SCAT crankshaft being so heavy during balancing and needing drilling.
Will
Will
To make a long story short.
Everything was balanced when we discovered that i had got the wrong pistons, Chris sent new ones and we had to rebalance it and add some weight to flywheel to get it right.
Dont ask me why and how, i am a newbee on this.
Crank, cam and camgear in place, next pistons and rod install.
This is my first enginebuild and doing it myself, with a little assist from my mechanic, great fun!!
If they added weight to the flywheel, what happens if you ever need to replace the flywheel?
Wait til you hear it fire up for the first time, something satisfying about knowing your two hands did it....theres nothing like the smell of a new motor when the paint strts warming up a bit, better than brownies out of the oven!
