gas line question
Old Feb 8, 2016 | 11:11 AM
Dins74's Avatar
Dins74
Hey madam what would you think of T 'ing off on the fuel inlet side befor the pump. Are these mech pumps strong enough to keep the carb full and recirculate fuel for a makeshift return
din
Old Feb 8, 2016 | 11:50 AM
7T1vette's Avatar
7T1vette
If you just T it back to the tank, the pressure in the line going to the carb will drop to almost nothing. You need an orifice in the line to keep pressure up. The .040" orifice mentioned is pretty small for an 8 gpm pump; also, that won't allow much flow in the return line.
But, it works...so that is one way to do it. My guess would be that anything under 1/8 inch would work fine. That should keep enough pressure in the carb line so that it would always stay 'charged'.
Old Feb 8, 2016 | 12:30 PM
ddawson's Avatar
ddawson
When I went from a QJet to a Holley I kept the OEM fuel filter with the built in return.
Old Feb 8, 2016 | 12:48 PM
colesweat's Avatar
colesweat
do they make different size lines for different motors? a 2 barrel 327 can not have the same line as a 427 l88! what do you think
Old Feb 8, 2016 | 01:20 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the tank to pump supply line for all 327,350,427,454 engines from 68-72 was 3/8" while the return line, (for applications that had a return line), was 1/4".
Regards,
Alan
Old Feb 8, 2016 | 01:34 PM
colesweat's Avatar
colesweat
why would it need a return line on a carb motor?
Old Feb 8, 2016 | 02:25 PM
ddawson's Avatar
ddawson
Vapor lock.
Old Feb 8, 2016 | 03:53 PM
madam's Avatar
madam
din
The supply line comes off the bottom of the tank and the fuel pump is lower than that therfore a gravity feed to pump is present. The return line to tank is near the top of the tank. Since the tee would be ahead of the pump fuel will never get there (up hill) ans serves no purpose. Plus you would have a closed system from pump to carb and could vaporlock.
Just my thoughts.
