Center gauge bezel
Old Feb 1, 2016 | 08:53 AM
rmgny44's Avatar
rmgny44
Default Center gauge bezel
The center gauge bezel on my '72 is either warped or was not installed properly. The top edge does not line up properly. There's about an 1/8" gap on the left side of the top edge. Anyone have instructions on how to remove it?
Old Feb 1, 2016 | 09:28 AM
Alan 71's Avatar
Alan 71
Hi R,
What you describe is a very common problem.
It's caused, I believe, by the fact that 6 different pieces contribute to the fit and alignment at this point.
The VERY FIRST thing you need to remember is…. DO NOT PUSH on the top of the bezel to try to improve the fit… it'll break in a heart beat.
Through careful fitting, shimming, and gradual tightening of the screws, you MAY be able to improve the fit to some degree.
Even original cars that have not had there dashes taken apart often have this mis-fit.
Sorry, no real help!
Regards,
Alan
This is a typical fit. It's a car that's not been apart.
Old Feb 1, 2016 | 11:58 AM
7T1vette's Avatar
7T1vette
This is VERY common for a factory-made part. It is due to the [cast] part being removed from the mold improperly (too quickly). MOST of that vintage C3 cars have deformed upper-left corners.
1. Accept it as normal and ignore it. (best alternative, IMO)
2. Try to fix it and it will break. Then you get to buy an aftermarket replacement for $200 that will have a nice, straight corner...but isn't 'original'.
The choice is yours.
Note: Those pot-metal cast parts NEEDED to remain in the molding machine long enough to cool/harden. The workers liked to 'speed up' the process so they could sit on their a$$es longer. Deformed parts are the result.
Old Feb 1, 2016 | 12:42 PM
rmgny44's Avatar
rmgny44
Originally Posted by Alan 71
Hi R,
Regards,
Alan
Actually your reply was a lot of help. I immediately stopped PUSHING ON IT! LOL Thanks, I'll just live with it!
Old Feb 1, 2016 | 12:44 PM
rmgny44's Avatar
rmgny44
Thanks for the reply, I'll live with it!
Old Feb 1, 2016 | 03:48 PM
ronarndt's Avatar
ronarndt
Default center panel
rmgny44- Take Alan 71's advice. I have had my dash apart a couple times and always use those plastic/nylon trim pry tools to pry on the padded dash instead of the metal bezel. I still always hold my breath, since there just is not much metal there to give it strength. My dash is pretty straight, but it is due to luck, not any skill on my part. RA
Old Feb 1, 2016 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi,
The bezel was designed to break on impact at that very narrow section of metal right at the top of the gauge cluster if a person hits the dash as a result of a crash.
What makes the original unbroken bezels so valuable is that there's not a completely accurate reproduction available for 69-71 model year cars.
I've wondered if they were ever broken while the dashes were being installed in St.Louis? Perhaps the workers knew just how well the bezel could typically be made to fit and no attempt was made to improve on it after the first try.
Regards,
Alan
Old Feb 1, 2016 | 04:29 PM
VETFEVER's Avatar
VETFEVER
I have owned 2 C3's with this issue and now I know why
Old Feb 1, 2016 | 10:21 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Just to add..
Original 70k mile car that has not been apart.
Willcox
Old Feb 2, 2016 | 11:52 AM
ronarndt's Avatar
ronarndt
Default Dash bezel
Alan
"What makes the original unbroken bezels so valuable is that there's not a completely accurate reproduction available for 69-71 model year cars."
So.....Although my car is a NOM car with hardly any original numbers matching parts, my center dash bezel is a collector's item? Barrett-Jackson here I come! Reserve is $100K.
Just kidding of course. RA
To Center gauge bezel
