drain hoses for astro ventilation.
thanks peter
It sounds like you're planning to replace the hoses with something you find locally.
You may very well be able to make that work, however the original hoses were 'flanged' on the one end that drains into the wheel well and that 'flange' is what formed the seal with the fiberglass wheel well. The hose is inserted through the round hole in the wheel well from the wheel swell into the interior. There's a drain plate and 3 rivets that hold it in place.
So are you trying to repair what you have, rig up something that'll work in place of the originals, or replace what you have with something like the originals?
Regards,
Alan
Regards,
Alan
Try Paragon Reproductions part #3897, for a coupe.
Astro Ventilation Plenum Drain Hose Kit.
The shields that go in the wheel well and fasteners are available too.
Of course as usual….not exactly cheap!
Regards,
Alan
thanks peter
