Preload on rear sway bar?
Old Mar 13, 2016 | 02:26 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Preload on rear sway bar?
I think I know the answer to this one before even posting the question. Should a stock rear sway bar be even given that the rear end is level? While finishing my new rear end install this morning, I noticed about an inch between the drivers side shackle and the resting sway bar eyelette. I presume it should be flat in its resting state? If so, is it worth trying to bend it back? It's a stock BB bar so not super easy to replace..
Old Mar 13, 2016 | 03:13 PM
Mooser's Avatar
Mooser
In a perfect world it would be level yes.
But I believe you'll find an inch twist over that bar at neutral you can pretty much almost do by hand.
The rear bars don't do a lot until more deflection than that happens
M
Old Mar 13, 2016 | 03:36 PM
zwede's Avatar
zwede
Swaybars are spring steel so I'm not sure how feasible it is to bend them?
I would probably shim the frame mount to equalize it before I'd try bending it.
Old Mar 13, 2016 | 03:39 PM
bashcraft's Avatar
bashcraft
It may break before it bends, but if it does bend, it's probably junk.
Old Mar 13, 2016 | 03:55 PM
7T1vette's Avatar
7T1vette
A sway bar that doesn't bend... Hmmmm... How do folks think they work?
Old Mar 13, 2016 | 05:57 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
You can definitely rebend the factory sway bars. I rebent mine for greater tyre clearance. I would in this instance too. Leverage is your friend.
Old Mar 13, 2016 | 07:16 PM
gkull's Avatar
gkull
I changed my 3/4
Old Mar 13, 2016 | 07:28 PM
CA-Legal-Vette
Thanks guys. I'll try to straighten it out.
It did occur to me though that the extra twist might be compensating for the extra weight that I've put on over the winter.
Old Mar 13, 2016 | 09:15 PM
gkull's Avatar
gkull
Mine was to wide on the ends............ So I clamped it in a big vice near the end 90 degree and I put a 4 foot pipe over the end and bent each end in
Old Mar 13, 2016 | 09:55 PM
Metalhead140
That's more or less what I did too, except I bent it inwards at the 90 and then reclamped and bent it outwards at the next bend, so the arms of the sway bar sat closer to the chassis rail where they went past the wheel and tyre.
Old Mar 14, 2016 | 07:32 AM
bashcraft's Avatar
bashcraft
So sway bars aren't made from spring steel?
Old Mar 14, 2016 | 08:37 AM
Metalhead140
Yep, they are. Yes you should be careful bending them (as any time working with springs or anything else with stored energy), and yes, potentially they can break if you overdo it, and release a lot of energy. But for small changes, and particularly on existing bends (rather than the torsion part of the bar), my experience is that it will be fine. A small amount of heat (well below changing colour of the steel) won't hurt to focus the location of the bend either. You need very high temperatures before you affect the temper. Full disclaimer, there is some risk of a swaybar breaking if bent cold, particularly if attempting large bends or in the torsion section of the bar. I wouldn't recommend doing that, if you need to for some reason then heat it properly hot, bend it, and have it retempered by a spring shop. But for small amounts on existing bends, I personally would do (and have done) it as have many others. If you are unhappy or unsure about any of this then farm it out, but any good home mechanic/fabricator with a decent shop can manage it in my opinion. There's plenty of info out there to research, as I did before doing it myself.
To Preload on rear sway bar?
