Temp gauge issue
Old Apr 6, 2016 | 09:44 PM
vannmike's Avatar
vannmike
Default Temp gauge issue
Trying to get the temp gauge working properly in my 77, and thought I had it. I started the car. I have a mechanical gauge to the head and the stock gauge to intake (sending units) Well they both started working and moving up. Once the engine got to about 205, both gauges were reading 205, so I was happy, but when the thermostat opens and the Mechanical gauge goes down to about 160-170, the stock gauge does not. Any ideas?
Old Apr 6, 2016 | 11:01 PM
BLUE1972's Avatar
BLUE1972
One gauge is closer to the return from the radiator, the other is closer to the feed to the radiator - engine to radiator hose. I would check the readings with a digital gauge to be sure. That is my best guess.
I get a 10 degree difference between the head and the manifold on my 71. High flow stat and spotless internals on the engine - just rebuilt.
Old Apr 7, 2016 | 04:32 AM
7T1vette's Avatar
7T1vette
Water temp in the head is more relevant. The stock system uses a sending unit in the left cylinder head. Just use the one in the car with stock sender in the head.
Old Apr 7, 2016 | 10:26 AM
vannmike's Avatar
vannmike
I understand that but if the gauges stays the way it is, I'll never know if the t stat is working basically
Old Apr 7, 2016 | 10:27 AM
vannmike's Avatar
vannmike
So is my engine, I could live with 10 degress, but 35-45 is too much for my comfort
Old Apr 7, 2016 | 11:54 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It could be a combination of things.. Location of the sender, the fact that the mechanical gauge is going to read more responsive than the electrical gauge and possibly an issue with the sending unit.
The senders have a wide margin for error when ascending from heat too. When we tested the senders years back the ohms going up varied from the ohms going down but they always came down eventually.
You might try a different sender and see if this corrects the issue.
Willcox
Old Apr 7, 2016 | 12:51 PM
7T1vette's Avatar
7T1vette
You won't know "when" the T-stat is opening. But you will know that it IS opening properly, because it levels off at acceptable running temperature. If the stat did not open, your engine temps would quickly climb to 240*F or higher.
Old Apr 7, 2016 | 01:31 PM
vannmike's Avatar
vannmike
Willcox
Wilcox, the sending unit I got was the one that advanced auto parts said was stock for the the 77 Corvette. It looks like a 3/4 npt. Thing is, my heads only have half or 3/8 threads. Any suggestions. Also do you sell sending units that are for sure the correct ohms for the 1977 year?
vannmike's Avatar
vannmike
Also this is crate motor
Old Apr 7, 2016 | 01:32 PM
vannmike's Avatar
vannmike
I understand that. But what I don't like is the idea that my gauge is telling me im driving around at 205, and in reality I'm driving at 165
Old Apr 7, 2016 | 02:06 PM
65GGvert's Avatar
65GGvert
What thermostat do you have in it?
Old Apr 7, 2016 | 02:17 PM
vannmike's Avatar
vannmike
Originally Posted by 65ggvert
what thermostat do you have in it?
185
Old Apr 7, 2016 | 02:24 PM
65GGvert's Avatar
65GGvert
185
Then if the thermostat is working it should not run 165. It should run 185 or more. Maybe your cooling system is so efficient the thermostat never opens. Normally not the case
Old Apr 7, 2016 | 02:30 PM
vannmike's Avatar
vannmike
If that is the case, then wouldn't the Mechanical gauge not go up to 205-210, then drop quickly to about 165-170 after a few minutes?
Old Apr 7, 2016 | 03:28 PM
0Willcox Corvette
Former Vendor
The sender is probably stock but the ohms won't read correctly regardless of where you get the sender. Some will be closer than others though. But the aftermarket heads all have 3/8"npt threads for the senders and unless you have another place to screw in the stock sender you'll need one 3/8"
I make an adjustable resistor that will dial the dash unit to match the sender. https://willcoxcorvette.com/corvette...resistor-77-82
I also make a 3/8 version of the sender that will fit your heads. However we make the one to two at a time so they are a bit on the pricey side. https://willcoxcorvette.com/corvette...79-3-8-npt-new
Willcox
Old Apr 7, 2016 | 04:18 PM
vannmike's Avatar
vannmike
Willcox
So in theory, I could go by a 3/8 sending unit for my heads, then your adjustable resistor to mate the gauge and the sending unit correct? Obviously I would need to know the ohms of the sending unit I get
Old Apr 7, 2016 | 04:39 PM
mikem350's Avatar
mikem350
No...each sender has a "curve" to the resistance. Unique to match each gauge. If you did manage to get it set, it would be accurate at only one temperature.
To Temp gauge issue
Old Apr 7, 2016 | 04:47 PM
vannmike's Avatar
vannmike
blehhhh. Might say forget it and buy autometers..
Old Apr 7, 2016 | 04:58 PM
0Willcox Corvette
Former Vendor
Mike... If you add resistance to the input line your are correct but the adjustable resistor is not installed inline. The adjustable resistor is installed on the dash unit in place of the stock resistor. Because the sender and the dash unit are both non linear the only way to make a linear change is to change the actual gauge resistor. This allows you to calibrate the dash unit to the sender.
Here is a video on how we did this... and why the adjustable resistor we make is awesome.
65-67
68-76
1977-1982
Old Apr 7, 2016 | 05:00 PM
0Willcox Corvette
Former Vendor
If you buy a factory sender that is 3/8 npt yes. I know there are aftermarket senders out there but I don't have any clue what the value range is on other aftermarket senders... Corvette didn't use them so I never tested them.
Willcox
