Is this a terrible thing to do? It's a heck of a lot more convenient than using a jack on each side and going back and forth. I placed the jack under the cross member beneath the differential. It seemed to work fine. Just wondering if this is a no-no. Thanks
I come in from the rear....and not from the side (but that is just me)....and depending on the exhaust...I will catch the plate for the rear leaf spring.
Originally Posted by resdoggie
It's easier to jack it up NASCAR style. It will not damage anything if your frame is solid.
Royal Canadian Navy
Jack up the entire side of the car midships where the crossmember is and then place your jacks fore and aft under the frame. Do the same for the other side. This is assuming your using a floor jack on wheels.
What is 'NASCAR' style????
DUB
I don't care who you are that is funny. (but maybe that is just my sense of humor)
About the worst damage you could do would be dent the crossmember...
Doesn't seem to have hurt the cross member.
is the exhaust in the way that you cant jack it by the spring mounting plate?
Yes
That's what I do if I'm jacking up the whole car. This time I was just doing the back.
I tried that and there wasn't room. I don't remember if it was the exhaust or what..
I usually try to 'catch' what I write and make sure it can not be interpreted 'differently'. I completely missed that one.....
Heck...I read it again and it made me laugh.
I say its still quicker to jack up from the side even if your only using rear or front jacks. Shouldn't take more than two minutes for both sides.
Well I did not know we were determining how FAST it could be done. When I am raising and safely supporting a customers Corvette...I honestly feel that they are not concerned on how fast I can do it...but rather.... how I do it.... protects their investment and also provides me with being able to get under a Corvette that is held up by safety jack stands.
Back to the post.
I have wood ramps that I can drive on that will raise the car 2 inches so I can slide my floor jack under it. Also..my floor jack has a very low saddle so I can get under a car very well....which makes a HUGE difference...and the saddle has teeth that are raised up more so they can catch on things to secure it when I am jacking.
I am not judging how person chooses to jack up their Corvette...But I have SEEN the effects of jacking it up on one side and then doing the other side and it has EVERYTHING on the angle of the frame and where it is contacting the jack stand...and THEN when you raise the other side....how well the floor jack can roll so the frame does not slide or want to push the jack stand due to how the floor jack is moving during it being raised.
I will stick with my method and those who do it differently....if you are happy with it and successful...I guess that is all that matters.
Reading this thread, made me thank God, I picked up one of these for our little private shop! I was so sick of jacking up the car and putting jack stands on it. It was one of the biggest PITA's, that I was glad to get rid of! Well worth the $1,500 I paid for it.
Nice lift....and it is a time saver ...that is for sure....unless you have not acquired them yet...I would get two of the safety stands that you can install under the car when it is up on the lift. And to prove my point...when you begin to get the wheels off the ground...WATCH the door gap at the front end by the windshield area ans see if it widens when the wheels lift off the ground.....this is allowing all the weight of the engine/radiator/suspension that is hanging out past where your supports for your lift are located on the frame and this 'hanging' of the front clip will begin to fatigue this area at the windshield cowl...and it will get a bit worse each and every time the car is lifted and allowed to hang. The severity of the gap widening is what it is. Yours may be good..but if you are aware of this and one day notice that it seems to get wider....then hopefully what I just wrote makes sense and that I am not just being overly paranoid. 'Just saying'.
Something like this in case you were wondering what I was referring to. Just an example.
TRUST ME...My method does NOT take all day. NOT even close...maybe 5 minutes to do all four wheels and jack stands if I had to guess. I do not time myself in how fast I can get it safely jacked up and supported. That is much like me trying to go super fast and beat the time given by an insurance company for 'set-up and measure' when setting up a car on a frame machine. I am MORE WORRIED that I have it correctly locked down so when I do pulls on it...it does what I want it to do. I guess it all depends on the person and how they choose to to do 'whatever' it is that they are doing.
Like I wrote...I AM NOT judging ANYBODY on how they do whatever it is they do. I do not have to warranty THEIR work.
I am just passing along my method so that there is an option. AND...just like you. I just feel my method seems to fit me better so I do not have to explain a problem to the customer in the side wall of a tire due to jacking it up from the side and having a problem,...or slipping off the stands...or causing the jack stands to tilt due to how the frame did not want to adjust on the jack stand correctly when being lifted from the other side.
You have your way that works for you...I have mine. I have no problem with that.
Royal Canadian Navy
DUB
You judged me and my method by implying that if I could jack my rear end up and place on jack stands in two minutes that is is somehow unsafe. Two minutes is not fast for me and the stands are positioned correctly. How is that unsafe? As for jacking it up from midships, I've never had any issues whatsoever for the 20 years of doing it this way. Just because you disagree with my way of jacking up my car does not make it wrong. My jacked up car is every bit as safe as yours or I wouldn't get under it. So, let's leave it at that.
