Timing ?
Old Apr 26, 2016 | 08:11 PM
croaker's Avatar
croaker
Default Timing ?
just a ? when setting your timing curve if your timing winds up say above 12 how do you prevent detonation or run on while shuting down?
Old Apr 26, 2016 | 08:19 PM
694speed350's Avatar
694speed350
what octane fuel and what is your idle speed? also what year is your car? And how are you trying to check timing? Do you have the vaccum line to the dist disconnected? in the old days When the timing was right on at about 30 in high gear at wot you would hear a slight ping
Old Apr 26, 2016 | 09:01 PM
croaker's Avatar
croaker
Just wondering on my question. I always disconnect and plug vacuum line to advance. 91 or 93 when I can get it. Just I've always just set my timing at idle never checked it at 3K. So my experince has always been at idle setting. Now I'm learning new tricks
Old Apr 26, 2016 | 10:18 PM
Mountainoakie's Avatar
Mountainoakie
A rich idle mixture combined with a fast idle speed will result in "run on".
Old Apr 27, 2016 | 01:00 PM
MelWff's Avatar
MelWff
you aren't telling us the complete story of what you are doing. It sounds like you are trying to set total mechanical advance to some number at 3k and are ending up with initial timing be higher than 12 BTDC. There is nothing wrong with that. If your idle speed is too high adjust the carburetor.
Old Apr 27, 2016 | 01:29 PM
croaker's Avatar
croaker
Actually I'm working on my interior. I just was reading some post and was wondering.
Old Apr 27, 2016 | 05:41 PM
rebel542's Avatar
rebel542
You'll get a different answer from anyone you ask so here is mine. Set your timing at 28 - 32 degrees total advance with the vacuum advance plugged and let the idle timing fall where it may. Simple.
Old Apr 27, 2016 | 08:15 PM
SH-60B's Avatar
SH-60B
Good gas and as low an idle as you can get. You can put a idle stop solenoid on it. Is it an automatic? If so, shut it off in drive.
Old Apr 27, 2016 | 09:45 PM
drwet's Avatar
drwet
Except I set my total timing at about 35 degrees all in by 3000 rpm. The exact number depends on the details of the engine - heads, compression, etc.
Old Apr 27, 2016 | 11:50 PM
OzBeast's Avatar
OzBeast
Recent story, might not help OP but the question was pretty vague anyway so here goes.
I had run on (or dieseling) start to occur over the past few months so I know I had to check it. Got a timing light and found my idle was at around 12, should have been 6-8.
Also turns out my distributor hold down bolt was slightly loose so I could actually rotate the distributor by hand with enough effort. That explains why the car went from well tuned to rough. I followed the hood tuning guidance for my 75 and set the idle timing back to 6ish, adjusted fuel/air mix with vacuum gauge and it is running SOOO much better.
I haven't even checked total timing, perhaps I should, but setting the idle to where it should be has made all the differences. Also, no run on.
Old Jun 20, 2020 | 10:23 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
The fuel is 3-4 yrs old !!!!! It's a wonder it even runs ! Get that crap outa there. I don't know if your lawnmower would run on that.
Old Jun 20, 2020 | 11:03 AM
lars's Avatar
lars
Initial timing has no effect whatsoever on run-on after shutdown. The ignition is "off" at shutdown, so there is no spark, and no effect from whatever the timing is set at. Run-on after shutdown is a function of the carb's throttle plate opening and engine rpm at shut-down. For best performance, total timing should be set to 36 (if stock heads are used), with initial timing in the mid-teens.
Lars
Old Jun 20, 2020 | 12:27 PM
MelWff's Avatar
MelWff
If you look you will notice that the thread is also over 4 years old!
Old Jun 20, 2020 | 04:01 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Run on may occur if using a multi spark CD ignition. MSD supplied a diode with my 6530 box to help prevent run on when the key is turned off.
Old Jun 21, 2020 | 11:51 PM
rebel542's Avatar
rebel542
You're exactly right drwet. My suggestion of 28-32 was to get you in the ball park. But you are correct in that you must consider your type of build.
To Timing ?
