th400 trans mount replacement
Old May 10, 2016 | 06:43 PM
stumpshot's Avatar
stumpshot
Default th400 trans mount replacement
Before I start, can the top bolts be reached without removing the cross member? Looks like the e-brake tab will be in the way even if the trans is lifted.
Thanks.
Old May 11, 2016 | 08:51 AM
jnb5101's Avatar
jnb5101
I installed a th400 into a car with a fixed crossmember, and didn't have any issues( the engine was out at the time). Does it look as though you can't access the bolts?
Old May 11, 2016 | 03:29 PM
stumpshot's Avatar
stumpshot
Jnb. Thanks for the reply. Looks like the passenger sie might be ok but the driver side is behind the e brake tab welded to the crossmember. I dont know if the x member can be unbolted and slid back along the exhausts or not. Just looking for now, not turning wrenches yet.
Old May 12, 2016 | 12:32 AM
cobrachuck's Avatar
cobrachuck
What year car is it ?
My 75 has a removable cross member I just did a 700R4 conversion still fresh in mind
Old May 12, 2016 | 11:27 PM
stumpshot's Avatar
stumpshot
Chuck, the car is a 75. Problem with the x member is the exhausts are welded all the way, front to rear. Only way to drop the x member is to cut the pipes.
Old May 13, 2016 | 06:21 AM
cobrachuck's Avatar
cobrachuck
I understand I had to cut mine as well Bummer
raise the transmission to make it easier
To th400 trans mount replacement
