71 Radiator Schroud Question
Old May 12, 2016 | 08:14 PM
Vettesic's Avatar
Vettesic
Default 71 Radiator Schroud Question
Removed and Had radiator leak fixed. Removing Schroud was not as hard getting back in. Is there a trick to it? Any suggestions would be appreciated!
Old May 12, 2016 | 08:31 PM
croaker's Avatar
croaker
Yeah get someone else to do it. I don't know how I didn't break mine. Good luck
Old May 12, 2016 | 09:18 PM
drwet's Avatar
drwet
If its the same as my 79 the shroud goes in before the radiator.
Old May 12, 2016 | 09:49 PM
_Austin_'s Avatar
_Austin_
I would never do it on my 72 but some people just cut the shroud in half to get it in.
Old May 13, 2016 | 02:07 PM
MelWff's Avatar
MelWff
you remove the bolts holding the radiator support on both sides and loosen the bolts on the bottom of the radiator support. You then push the radiator support forward to get clearance to install the radiator and shroud together.
Old May 13, 2016 | 04:14 PM
Vettesic's Avatar
Vettesic
Thanks. I did all of the above. Installing rad and schroud together is quite a major effort!!! After flinging some 1/2 inch wrenches and lots of selective language and effort I managed to squeeze rad in after schroud. Miserable job. Funny, I did this same job on my 80 many years ago and do not remember any of this hassle.
Old May 13, 2016 | 11:43 PM
7T1vette's Avatar
7T1vette
If you have A/C, the job is much worse....
Old May 14, 2016 | 08:23 AM
croaker's Avatar
croaker
So what worked for you?
Old May 14, 2016 | 11:33 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
install shroud over water pump/ fan first, just leave it lay loose.
then install radiator, as you are getting radiator in place,
move shroud to general final location.
then bolt down radiator, then shroud.
Old May 14, 2016 | 01:04 PM
Vettesic's Avatar
Vettesic
Placed schroud in basic location and sqeezed radiator in. It's just about 0 clearance. Installing shroud and rad together did not seem to work for me. Even with a/c compressor moved aside. As stated its one difficult job.
Old May 14, 2016 | 04:05 PM
7T1vette's Avatar
7T1vette
If I had to do that job over, I would have used my Sawzall to cut thru the center of the shroud bottom, then patch it together when in final location. It would have been a LOT easier.
Old May 14, 2016 | 05:07 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It will press in.....it will also seem like you are going to break it while trying.....but once you get the hump over the control arm...it drops in....
Did two in 5 months.....as long as the shroud is not brittle....it will not break.
Mine is the original 72' shroud.....and I got it in intact.
Jebby
Old May 14, 2016 | 05:22 PM
CanadaGrant's Avatar
CanadaGrant
I always remove the rad/shroud/support as a complete unit. It is a straight forward job with no hassles and minimum to no swearing. Two support bolts underneath, three in each fender well, one brace and the ground strap,the hood and other than draining and removing the hoses and fan with clutch, you are good to go. The whole thing lifts right out and you can service everything. Mine is a 69 427 and my idea is that cutting the shroud to remove or replace it or the rad is a butcher job at best. I have also done my wife's 78 the same way. It is at most a 2 hour job to remove or to replace and it sure beats standing there looking at it in frustration.
Old May 14, 2016 | 06:06 PM
7T1vette's Avatar
7T1vette
You obviously don't have A/C in either car. Or, you have a lot of B.S.
Oh...one more possibility....you are the master genius mechanic with world fame and have no peers on this Earth.
Which is it?
Old May 14, 2016 | 09:23 PM
CanadaGrant
Which is it?
My claim to fame is just trying to do it right and cutting stuff up isn't there. You can pull the whole unit straight up and out with less trouble but the real trouble is trying to get it back in again without doing it. It seems the only BS is the guy who advocates cutting up parts to get them back into the car with more problems than doing it the way it was installed in the first place. I always looked forward to your posts but you seem to be advocating some sort of "let's cut it up" approach when it really isn't hard to pull the whole unit like I said. It works and that is how it is supposed to be done and is way easier.
"you are the master genius mechanic with world fame and have no peers on this Earth."
Why, or where would you even dig this crap up from? I am none of the above. I bought my first Corvette in 1970. It was a 69 427 and have owned just under 40 of them since. I now have my 69 and my C6 Z06 while my wife has had her 78 S/A for over 20 years. I have owned an engine shop since 1971 but do not consider myself a genius, have no world fame, and most of my peers know a hell of a lot more than me. All I advocated was that doing it the right way was actually easier in the end with less frustration or cutting up perfectly good parts.
Old May 15, 2016 | 08:26 AM
croaker's Avatar
croaker
I still have nightmares of this job and, I did it about 7 years ago. I've seen posts where people have pulled the whole unit out with support.i thought that would still be tough with A/C. I have to pull it again soon but not looking forward to it
To 71 Radiator Schroud Question
