74 engine harness sealant
Old May 13, 2016 | 04:29 AM
Vaipulu's Avatar
Vaipulu
Default 74 engine harness sealant
I'm replacing the engine harness as it looks to be a potential fire hazard. I can see where the lights/ignition harness plug into the back of the fuse block through the firewall. There seems to be some kind of rubberized coating or sealant on the firewall over the plugs. What have you guys used to get it off? After you've installed the harness did you re-seal it? Thanks in advance.
Old May 13, 2016 | 06:52 AM
Alan 71's Avatar
Alan 71
Hi V,
Welcome!
First Post!!
I used a small putty knife and flat screwdriver to scrape as much of the sealer off as possible.
I cleaned the area up using lacquer thinner which does a good job.
After installing the new connector I sealed it in place using some roofing sealer from my local home store.
As you work on getting the old sealer off you see that there are actually 2 connecters that siamese together at that point… the engine harness and the forward lighting harness.
Good Luck.
Regards,
Alan
Old May 13, 2016 | 12:45 PM
mikem350's Avatar
mikem350
I always spray some WD40 on any connector terminals. Use as little as possible. Keeps corrosion away, and will not hurt anything.
Old May 13, 2016 | 02:28 PM
Vaipulu's Avatar
Vaipulu
Thanks for the fast reply! Good idea about the roofing sealant. Wish me luck, first time replacing a harness, this lectric harness seems to be spot on so hopefully, this black "stuff" is the worst part.
Again, Thank You
Old May 16, 2016 | 07:09 AM
gungatim's Avatar
gungatim
the proper stuff to use is dielectric grease. the WD40 won't keep any corrosion away long term, it's too thin and evaporates quickly.
Old May 16, 2016 | 09:20 AM
7T1vette's Avatar
7T1vette
To 74 engine harness sealant
