Brake light reset
Old May 14, 2016 | 07:33 PM
gsimon767's Avatar
gsimon767
Default Brake light reset
The brake warning light came on because of a leaking front caliper. I refilled reservoir and bled front brakes. Light stays on. Do I have to bleed rear brake also to release valve. Car is a 75.
Old May 14, 2016 | 08:03 PM
'75's Avatar
'75
Do you have a solid pedal and does it stop well? Also make sure the parking brake isn't pulled, it uses the same light.
Old May 14, 2016 | 08:46 PM
7T1vette's Avatar
7T1vette
You have to bleed the brakes. Then, you have to panic stomp the brake pedal to get the shuttle valve to re-center in the distribution block. Until that light goes out, the shuttle valve is only allowing 1/2 of your braking system to function.
Old May 15, 2016 | 01:03 PM
gsimon767's Avatar
gsimon767
If I open the rear brakes shouldn't that release the pressure from the rear that caused the shuttle valve to move off center thereby re-centering the valve?
Old May 16, 2016 | 12:28 AM
7T1vette's Avatar
7T1vette
Nope. There is no pressure in either line until the brakes are applied. It will just stay right there. Just do it.
Old May 16, 2016 | 09:26 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
You dont even need to drive it to reset it. Just get in and press the brake pedal HARD. It doesnt need to be a fast jab just apply REALLY FIRM PRESSURE with the key on you'll see the light go out.
Old May 16, 2016 | 10:15 PM
7T1vette's Avatar
7T1vette
Good luck with that. I hope it works...
To Brake light reset
