Bought a used C3...
Old May 16, 2016 | 07:31 PM
C3fanatic_'s Avatar
C3fanatic_
2nd Gear
Default Bought a used C3...
This last weekend I bought a used 1979 and the seller said it just won't run well. At 3000$ I couldn't help but pick it up for it looks really good. I turned it over after I got home and it sounds like one or more cylinders are misfiring. I know what this can be caused by but I don't know how to find witch cylinder(s) are/is the problem. Any ideas or tips?
Old May 16, 2016 | 08:03 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Pull plug leads in turn, see which ones make no difference would be a good start?
Old May 16, 2016 | 08:07 PM
BlackC3vette's Avatar
BlackC3vette
Loosen the plug wires at the cap, raise up the idle rpm slightly so it doesn't stall on you. Pull the plug wires one at a time to find out which cylinder does not make much of a difference with the rpm. Be careful with the plug wires, the spark can jump right up a pair of pliers. Use a plastic plug wire puller or wear gloves.
You can also pull the spark plugs to see which one is not firing. If I did this, I would probably put new ones back in. The misfiring could be a bad plug. If you do have a bad plug, you need to investigate how it got that way. Or, it could be a compression problem. Or.........
Old May 16, 2016 | 08:34 PM
C3fanatic_'s Avatar
C3fanatic_
2nd Gear
thanks a lot! It was a plug not working properly so I just replaced all of them.
Old May 16, 2016 | 08:40 PM
keithl1967's Avatar
keithl1967
Before you try to run it...pull the valve covers and turn the motor over by hand...make sure all of the valves open and close...It might not run right because of a bad cam lobe or two...
Old May 16, 2016 | 08:46 PM
Giant_Robot's Avatar
Giant_Robot
They are all used.
Old May 16, 2016 | 09:19 PM
BlackC3vette
Originally Posted by Giant_Robot
They are all used.
Yes, but when we buy them, they are new to us.
Old May 16, 2016 | 09:30 PM
cobrachuck's Avatar
cobrachuck
Welcome
Good luck great bunch of folks here
Old May 16, 2016 | 09:49 PM
Oldguard 7's Avatar
Oldguard 7
Originally Posted by c3fanatic_
this last weekend i bought a used 1979 and the seller said it just won't run well. At 3000$ i couldn't help but pick it up for it looks really good. I turned it over after i got home and it sounds like one or more cylinders are misfiring. I know what this can be caused by but i don't know how to find witch cylinder(s) are/is the problem. Any ideas or tips?
this thread is useless wothout pics
Old May 16, 2016 | 10:01 PM
htown81vette's Avatar
htown81vette
On my drag car (that uses headers) I always bring along my laser temp sensor and just point it to the header on each cylinder. It's always very obvious which cylinder is not firing. And the best part about it is you don't even have to get your hands dirty. I'm not sure how it would work on stock manifolds though, never tried it.
Amazon.com: Raytek MT4 Mini Temp Non-Contact Thermometer Gun with Laser Sighting: Home Improvement Amazon.com: Raytek MT4 Mini Temp Non-Contact Thermometer Gun with Laser Sighting: Home Improvement
Old May 16, 2016 | 11:31 PM
Alwyn678's Avatar
Alwyn678
They are all used.
First thing I thought. Sounds like the advice is Great.
Old May 17, 2016 | 09:18 AM
augiedoggy's Avatar
augiedoggy
same here... I was going to ask where one could go to get a new one
Sounds like an awesome deal! ... I paid around 3k for mine and everything needed serious attention... 4 years later and the interior, engine , exhaust and bodywork is pretty much done... off this week to complete it and hopefully shoot the primer and paint it before july... in hindsight it would have been nice to buy one that needed less work.
Old May 17, 2016 | 09:32 AM
71scgc's Avatar
71scgc
A timing light can be used to find the missing cylinders as well. Just move the pickup from plug to plug and look for erratic (or nonexistent) flashing from the light. If any are found, pull and read plugs, ring out cables, etc.
Carter
Old May 17, 2016 | 11:12 AM
Mark Riles's Avatar
Mark Riles
Fouled plugs isn't usually random. It's typically a symptom of a bigger problem. What color were the ends when you pulled them? Fouling is caused by any number of fluid sources. Rich mixture, oil blowing by the rings, or coolant from a bad head gasket. All can be checked but you need to figure out what fouled the plugs to begin with. , post pics.
Old May 17, 2016 | 11:59 AM
GUSTO14's Avatar
GUSTO14
So does that mean that you now have it up and running?
Welcome to the Corvette Forum and good luck with your new acquisition. Post some pictures when you get a chance, we love pictures here!
GUSTO
Old May 17, 2016 | 01:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
All good tips
A common one is to mix up 5 and 7 on the cap
Done it a few times. will start and seem to run ok but not right.
Ditto on looking at the bad plug then find out why it fouled something else is going on that made it that way
Old May 18, 2016 | 12:49 PM
bluedawg's Avatar
bluedawg
Xs 2...
To Bought a used C3...
