Considering stroking it (L-48)
Old Jun 7, 2016 | 12:09 PM
heirloomvette73's Avatar
heirloomvette73
Originally Posted by myohpe@gmail.com
I chose to build an engine from the block up, because that way I could still drive my car while I saved for parts and waited on the machine shop(they seem to take forever). I would suggest if you want to buy a block to build, that you start with a 400 block.
Thanks for your input! I was literally just researching some options when I saw your post. I noticed "400" blocks in the Gen 1 SMC category. What does this mean in terms of adaptations in the engine bay? I assume that would be heavier, as well?
I think I'm right there with you on the "build a stroker and drive" plan. I would hate to not be able to drive the vette while working on it- it would make me impatient, and that is never a good thing. Not to mention I could save the original engine (the car was originally my late Father's- sentimentality isn't always practical).
To that end, can anyone speak to what I'm "looking for" in an engine block? Being new to car mechanics, I don't see anything that seems to tell whether or not it will "drop in". I'm looking for "drop in"- less hassle and money.
I'm having a lot of fun planning this project guys, and your input is absolutely what I'm looking for.
Old Jun 7, 2016 | 12:31 PM
myohpe@gmail.com's Avatar
myohpe@gmail.com
Default 421 Stroker
That's the great thing about the small block 400 engine, it is the same block as the 350. Same engine mounts, same oil pan, same flexplate, same cyl heads(except steam holes should be drilled when using 350 heads on a 400). So the whole thing drops right in and uses the same engine mounts. I would suggest, however, that because of the massive increase in torque you have from the 421, that you use solid or polyurethane engine mounts. Also, seek a 400 block with stock 4.125" bore. Because the cylinder walls are siamesed, you shouldn't overbore beyond +.030"(4.155 bore). Happy Building! Oh, here is a pic of mine.
Old Jun 7, 2016 | 12:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
curious on that aircleaner deal what brand? How big diameter are the tubes? Think its restrictive at all?
Been lookiing at different idears for a temp cold air solution til I can come up with something stellar. Non vette so I wont elaborate but have the hold for WW motor open like yours.
Old Jun 7, 2016 | 12:45 PM
myohpe@gmail.com
Default Air Cleaner
It's a Spectre low profile air box with a 4" dia pipe. I have it plumbed into the cowl area for cold air intake. Filter is a foam piece in the black velocity stack mounted in the cowl. It's supposed to flow over 800cfm, according to Spectre. The whole system including air box, pipe and velocity stack cost under $200. Adds free horsepower, if you're willing to cut a hole in your Corvette's cowl. I was, since 1979 wasn't a high dollar year for resale value.
Old Jun 7, 2016 | 01:36 PM
heirloomvette73
First off, holy mother of metal. I'm not sure I can even tell whats going on in that picture, except that looks like one dynamite asphalt destroyer.
Secondly, I'm looking at 400 blocks online now. This is what I've found:
http://www.summitracing.com/parts/dr...make/chevrolet
about $1700.
They are way more expensive than just doing a 350->383 conversion.
This is pretty much what I'm looking at, yes?
Old Jun 7, 2016 | 02:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
Those Dart blocks are real nice and strong the little M even better!
If you wanted a 421 thats bulletproof thats the way to go
Internally balance it not many could tell what it was
Know a motor that size you almost cant use too much head/intake no need to use "small" parts to help with low end tq. Youll love it, BBC power and tq in a sbc package.
initial sticker shock yes but worth it long run
By the time you take a GM 400 block clean mag and machine it "right" youre not that far off from the cost of one that will hold up to whatever you throw at it.
Think Dart among others even sells assembled shortblocks if thats your thing, can build to suit
383 wont even compare, youll look back at the 350 and say what was that a starter motor? LOL seriously its THAT big a difference.
Old Jun 7, 2016 | 02:28 PM
myohpe@gmail.com
Default Stroker
about $1700.
It all depends on which parts you use for your build. I didn't buy my block from an aftermarket outfit. I paid $120 for a stock 400 bare block I found on Craigslist. After costs for machining, I had about $780 in it. That alone saved me big money, and I knew I could use a stock block as long as I made sure the cylinder walls were thick enough, and it had no cracks anywhere. The cost of most of the other parts would be nearly the same, depending on how bulletproof you build your engine. Putting a forged 400 crank in a 350 block to make a 383 costs about the same as putting a 3.875" stroker crank in a 400 block to make a 421. Rods, pistons, cam lifters, all cost nearly the same. So why not go for the big cubic inches? Built with a forged rotating assembly and roller cam, either engine will probably cost around $5K to complete.Just be damn sure your transmission and differential can handle the torque, you can easily get 550 to 600 ft/lbs of torque from a 421. Super tire spinning fun. Yeeee-Hah!
Old Jun 7, 2016 | 02:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cost on stroker kits has really gotten affordable over the yrs would hav e ahard time using a 400 block and not stroking it
Just the slightest crack of the throttle and youre moving
Go back and forth about a BB or just abigger SB
No need for steep gears, shaft rockers etc. RPM costs money and dont last as long. If i had half a brain would have done a mild 4xx and tossed a B&m/holley street blower, HR cam and been able to DD it....cross country if needed. Now have to buy a hauler just to go 2 hrs to the track not keen on burning u psolid roller valvetrain for fwy commutes.
Man I need to quit eating over this keyboard
Old Jun 7, 2016 | 04:10 PM
heirloomvette73
Well I've finally begun the used engine hunt. I'm going to see what I can find and go from there. Man that 421 sounds delicious. I have the 4 speed close muncie in there now- I'm fairly certain people have used those in high horsepower cars (chevelles, etc).
You guys have any clue what "minor burn" or "burn" means for a used engine? Google keeps trying to give me first aid.
Old Jun 9, 2016 | 01:47 AM
PHLGUZZ's Avatar
PHLGUZZ
383 Stroker Roller Motor. Air Flow Research Heads. 2500 stall convertor, 700 R4 auto.<br/>
Old Jun 9, 2016 | 06:22 AM
SH-60B's Avatar
SH-60B
Is that in a description referring to the condition of a motor in an ad? Maybe he means it burns oil.
Old Jun 9, 2016 | 09:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Spot in cyl wal perhaps? Keep looking
Old Jun 20, 2016 | 10:22 AM
  #33
heirloomvette73
Dearest Vette Owners:
Anyone have an engine stand they could recommend? looking for something inexpensive and functional.
I found a (supposedly) operational (1978) 350 cubic inch for $300 bucks, plus some additional parts. Gotta have something to mount it on.
Thanks,
Dan
Old Jun 20, 2016 | 11:57 AM
  #34
bluedawg's Avatar
bluedawg
Thanks,
Dan
I bought mine a Napa, thier beefsteak one for 150.
Old Jun 20, 2016 | 11:59 AM
  #35
AboveTheLogic's Avatar
AboveTheLogic
I use the 750lb stand from Harbor Freight that costs $48 w/o a coupon:
I wouldn't recommend it. Go at least with the 1000lb stand:
The 1000lb stand costs $60 w/o a coupon, but that bar across the front should really help with the stability.
Old Jun 20, 2016 | 12:02 PM
  #36
cv67's Avatar
cv67
St. Jude Donor '05
Summits got some, reasonable.
Cradles with wheels are nice to have
Old Jun 20, 2016 | 12:50 PM
  #37
Ibanez540r's Avatar
Ibanez540r
Thanks,
Dan
With your admittedly limited knowledge, post details here before you pull the trigger. If it's a stock 350 for your plans, no sense in buying it for $300. All you need is a bare block, everything else will be replaced. You should be able to pick up a good block for $100 or less.
To Considering stroking it (L-48)
Old Jun 27, 2016 | 01:23 PM
  #38
heirloomvette73
Okay, I have the 1978 350 w/ 4 bolt mains and I'm in the process of taking it apart. No one warned me how much fun getting dirty and taking these things apart can be! (seriously!) From what I have seen so far, it's in pretty good shape (minor bore rust being the worst problem).
Anyway, I'm still looking at buying a rotating assembly. At this point the one thing I would like to avoid is clearancing the block (if possible at all). Obviously the only way to do that would be to invest in rods that have additional clearance (such as these: https://www.summitracing.com/parts/s...make/chevrolet).
Has anyone ever found the "magic bullet" for reducing the amount of clearancing required, or better yet- not requiring grinding at all? I would obviously never just "trust" something to work out and check clearances anyways, but it would be nice if it worked straight away.
Thanks,
Dan
Old Jun 27, 2016 | 09:59 PM
  #39
Ibanez540r's Avatar
Ibanez540r
Dan,
I'd go with the SCAT I beams. H beams are overkill, and although debatable, I beams are actually a stronger design.
Depending on the details, the Scat Pro Comp I beams with the 7/16 ARP rod bolts are nice pieces for the money. (I'm running this rod with a bolt upgrade in my supercharged 383 build) The Scat Pro Stock with ARP 3/8 bolts are a bit cheaper and still a nice upgrade over stock.
Check out Skip White on Ebay, he's had them both for the cheapest I've been able to find.
Old Jun 27, 2016 | 11:34 PM
  #40
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I agree on the Scat rods, I'd go (and have in the engine I'm putting together for my Vette at the moment) for 6" rods while you're at it.
