Which Water Pump?
Old Jun 3, 2016 | 02:21 PM
jgcable's Avatar
jgcable
Default Which Water Pump?
You guys haven't steered me wrong yet!
I need a new water pump for my 77 L48. Its a stock motor.
Every local store and online store has several to choose from
Pricing for a stock cast iron pump ranges from $26.00 to $60.00. Some come with gaskets... some don't. There are just too many choices!!
A few buddies of mine said I should go OEM. Is that even possible?
I would like to just run down to the local Auto Zone, Pep Boys or Advanced Auto and pick one up but they all have several to choose from. What is the "approved" Forum pump???
Old Jun 3, 2016 | 03:26 PM
71 Green 454's Avatar
71 Green 454
Is there a NAPA parts store in your area?
If you decide to run down to the above mentioned parts stores, I would take the old one with me to make sure it matched up. Inlet, outlet, shaft size, and depth.
Old Jun 3, 2016 | 08:27 PM
GUSTO14's Avatar
GUSTO14
Your Corvette uses a "short" pump, so don't let anyone tell you otherwise. The Corvette also used a larger pump shaft for a while in the 70's. So be sure to take your old pump, or at least the water pump pulley with you. The shaft needs to fit the hole in the pulley exactly or you're asking for a bunch of frustration.
71-82 Corvette uses the 3/4" water pump shaft.
http://www.jegs.com/i/PRW/228/143500...FcNkhgodnREG8w
Other than that it's just a small block water pump.
Good luck... GUSTO
Old Jun 3, 2016 | 09:32 PM
Peterbuilt's Avatar
Peterbuilt
Default Good advise.
Here are the dimensions that you need.
Old Jun 4, 2016 | 08:16 PM
croaker's Avatar
croaker
Do a search on the pump from NAPA that the housing broke.Posted last week
Old Jun 4, 2016 | 09:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Hard to tell anymore whats good
Will say their trans mounts are complete garbage threads dont really fit metric or std
If you can find an older auto pts guy they can probably tell you , there are different grades of same parts made by ea mfr
Old Jun 4, 2016 | 09:52 PM
The13Bats's Avatar
The13Bats
https://www.corvetteforum.com/forums...in-t-good.html
https://www.corvetteforum.com/forums...c-failure.html
There has been an alarming trend in water pump mishaps lately something to be honest I never gave a heck of a lot of thought to,
After the threads above I would have to ask mr Willcox which one would he would install/sell and go with that and hope...it's scary the crap parts out there.
Old Jun 5, 2016 | 08:43 AM
croaker's Avatar
croaker
It's got to where everything you buy is pretty much junk. The old saying you get what you pay for doesn't save you either. Sometimes I think only the box or label was made in America
Old Jun 5, 2016 | 08:44 AM
croaker's Avatar
croaker
Don't they make a rebuild kit for water pumps?
Old Jun 5, 2016 | 09:01 AM
GUSTO14's Avatar
GUSTO14
Apparently someone does...
http://www.classicmuscle.com/p-23351...FYIfhgod54MJsw
Good luck... GUSTO
Old Jun 5, 2016 | 09:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
might be the answer. 10 yrs ago people would post displeasure about others buying overseas cheap stuff defending it to the death.
This is the result we dont really have choices anymore.
Old Jun 6, 2016 | 12:18 PM
pws69's Avatar
pws69
Short-Style Pump for most 1955-72 cars & trucks (5/8" pilot shaft)
- Fits all 1955-68 S/B Chevy passenger cars, 1969-70 350 c.i.d. Corvettes and 1955-72 light duty trucks.
- Has 3/4" ball/ball bearing.
- Dimension from block surface to hub: 5-5/8". Inlet diameter: 1.80".
Long-Style Pump for 1969-87 V8, 90° V6 & 1973-86 truck (5/8" pilot shaft)
- Fits all 1969-87 S/B Chevy or 90° V6 passenger cars and 1973-86 light duty trucks. Does not fit Corvettes (use #8810 or #8812) or
late-model vehicles with serpentine accessory drive belts (use #8881).
- Has heavy-duty 3/4" ball/roller bearing.
- Dimension from block surface to hub: 6-15/16". Inlet diameter: 1.80".
Short-Style Pump for 1971-82 Corvettes 3/4" pilot shaft)
- Fits all 1971-82 S/B Corvettes.
- Dimension from block surface to hub: 5-13/16". Inlet diameter: 1.80".
To Which Water Pump?
