Jacking up rear end from "Batwing" on an '80?
Old 06-05-2016, 09:13 AM
gbarmore
gbarmore's Avatar
Default Jacking up rear end from "Batwing" on an '80?
Looking for an easier way to get my car jacked up for the frequent under-car needs, tire swaps, etc. I usually back the car up on steel ramps, but the other day when I was pulling forward off of them, they slipped and went shooting out causing my car to crash down which compressed the suspension and the left rear fender crushed down on the ramp causing damage to the fiberglass / paint. Awesome.....
Anyway, is there any risk using the bottom center of the 'batwing' on my 80 as a jacking point? It would seem to me that is the area that carries the entire load of the rear end via the spring anyway. Once jacked up I would use blocks under the wheels and remove the jack.
Old 06-05-2016, 10:58 AM
BlackC3vette
BlackC3vette's Avatar
The first problem I have with lifting mine up that way is, it's aluminum. The wing is also the cover that bolts on and from a design concern, I think it needed a couple more.. I just use the frame rails, either one at a time or I roll out a second jack.
Old 06-05-2016, 11:05 AM
SH-60B
SH-60B's Avatar
I built some wooden ramps years ago for a camaro that are 5' long with a 10" rise. Something like them would be very stable, I use them for the Vette now. When I remove wheels I always jack on the frame as mentioned.
Old 06-05-2016, 11:31 AM
'75
'75's Avatar
The bottom of the batwing is where the spring is mounted, it holds the car up all day every day, I can't see how it would hurt it to put a jack under it to lift the car.
Old 06-05-2016, 01:38 PM
BlackC3vette
True, the spring mounts to the bracket on the diff. and is designed, cast, machined to be the anchor point. When it's all bolted together, it is a system (aluminum)that supports the weight of the vehicle. You can jack up your 80 wherever you want, my comfort zone uses the frame rails.
Old 06-05-2016, 01:49 PM
mikem350
mikem350's Avatar
Yes I do it all the time! The jack cup is tight fit over the exhaust, have to shove it in
Old 06-05-2016, 02:01 PM
'75
'75's Avatar
My thoughts, the recommended jacking points are just that, recommended for using the original jack to change a tire by the side of the road. Using a floor jack to lift the entire rear of the car at the point that the car normally sits on,(rear spring mount at the diff) is safer than lifting from points on the side frame. It lifts the rear evenly so two stands can be set, no frame twisting for those with frame issues and no setting one jack stand at a time and then lifting the other side to set another one. Mostly, I just use my 2 post lift.
Old 06-05-2016, 07:36 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
...AND the 'bat wing' is NOT taking all the weight also...because there is a FRONT mount also.
30+ years of jacking it that way and NEVER ONE PROBLEM...do as always....DO AS YOU WISH.
DUB
Old 06-05-2016, 09:40 PM
gbarmore
gbarmore's Avatar
DUB
Thanks everyone! Glad to hear others have been jacking from the spring mount without issue. I may build some ramps eventually but I have enough projects for now.
Appreciate the input.
Old 06-06-2016, 03:42 PM
jim-81
jim-81's Avatar
On mine, I can't get to the diff because of the exhaust right under it, and yeah I'm not sure I'd want to lift it from the aluminum diff. I recently used the cross member right before it: https://www.corvetteforum.com/forums...nder-diff.html
To Jacking up rear end from "Batwing" on an '80?
Quick Reply: Jacking up rear end from "Batwing" on an '80?
