Console Shift Pattern Plate
Old Jun 8, 2016 | 02:16 PM
One Owner's Avatar
One Owner
Lifelong Vette Lover
Default Console Shift Pattern Plate
I'm a new member, albeit a long time Vette owner. My 69 console is original but the shift pattern plate has been scratched over the years. I tried a few different paint restorations, none of which were really acceptable. Does anyone know how the plate is mounted as I am concerned about getting the old one off without damaging the console and it appears to be glued, welded, ?????. Thanks for whatever help you can provide.
Old Jun 8, 2016 | 02:22 PM
Alan 71's Avatar
Alan 71
Hi OO,
The 4-speed shift pattern plate is held in place with adhesive.
They can sometimes be pried off without bending them.
If you want to try to restore yours you can remove the paint, and then spray it with semi-flat black paint. Krylon #1613 and SEMS semi-flat black are 2 possibilities.
After spraying you can use an x-acto knife blade to gently remove the paint from the raised shift pattern.
The reproduction plates are pretty nice so they're an option too.
Good Luck!
Regards,
Alan
I painted this with Krylon in place on the shifter console plate because I didn't want to take a chance of bending it trying to remove it. It was out of the car though so I had good light and access doing it.
Old Jun 8, 2016 | 02:42 PM
One Owner's Avatar
One Owner
Originally Posted by Alan 71
Hi OO,
Good Luck!
Regards,
Alan
Thanks, Alan. I have shot it a couple of times and have had some fish eyes, orange peel effect, so I'm frustrated! I did use some stripper to remove the old paint and then washed it with acetone and water to try to neutralize it and make the surface as clean and smooth as possible. I'll give it one more shot (pun intended) before ordering a new one. Thanks again.
Old Jun 8, 2016 | 04:06 PM
Alan 71's Avatar
Alan 71
Hi OO,
If you used ANYTHING in the interior that had even a hint of silicone in it you'll see those fish eyes.
TOUGH to get rid of completely!
Regards,
Alan
Old Jun 8, 2016 | 05:08 PM
One Owner's Avatar
One Owner
Hi OO,
Regards,
Alan
I've had this car apart so many years, I can't remember BUT I don't think I used anything on it that had silicone! That said, I'm at the age where I no longer guarantee any memory-based info.
Thanks Alan
Old Jun 10, 2016 | 03:43 AM
7T1vette's Avatar
7T1vette
For best results, any metal part needs to have ALL paint chemically stripped first, then part needs to be cleaned WELL with detergent, rinsed repeatedly and thoroughly dried. THEN you can paint it will satin black or semi-flat black paint (different paint mfgrs. give different labels to the same sheen paint). As ALAN71 mentioned, you can shave soft paint off raised chrome with an X-Acto knife or wipe it off with clean cloth and lacquer thinner (carefully!). Either method works.
Old Jun 10, 2016 | 07:37 AM
One Owner's Avatar
One Owner
Thanks, guys. I did order the new replacement plate but I'm gonna try it one more time as it seems like a bear getting the old one out without damaging the console around it. I really appreciate your guidance!
To Console Shift Pattern Plate
