Wiper door question
Old Jun 25, 2016 | 07:15 PM
TheGreek!'s Avatar
TheGreek!
Default Wiper door question
The windshield wiper door on my 69 works and all but I have a question, is it normal for it to pop up and then go back down when the car is started? If it's not normal what needs to be done to correct it? This is my first corvette, I'm still trying to learn all the little nuances of them.
Old Jun 25, 2016 | 07:24 PM
Alan 71's Avatar
Alan 71
Hi TG,
No, the door should stay closed upon start up.
I wish I could say it's easy to find the cause but it's not.
Do you have a Chassis Service Manual and/or a vacuum system trouble shooting guide?
Regards,
Alan
Someone recently posted that they cured their long time wiper door rising by replacing the vacuum valve located in the wiper bay under the right side wiper transmission…. but your troubles could easily be caused by something else.
It's good to be able to test the individual components to determine what's working and what's not rather than just buying parts until you happen to replace the one causing the problem.
Old Jun 26, 2016 | 12:29 AM
Dave J's Avatar
Dave J
Alan is right, The most common issue for wiper door winking on startup is the wiper safety valve located under the passenger side wiper arm. There could be another issue or a combination also.
Do you have a Mityvac or equivalent vacuum pump? If so, report back and we can talk you through a test sequence to make a correct diagnosis.
You could also try bypassing the safety valve to check it's operation. There are 3 ports on the valve. Ignore the top one. it is only a vent. Pull the middle and the lower vacuum hoses off the valve and connect them with a small short tube.
Start the car, and if the "winking" went away, you found your problem. DO NOT replace it with the $25-$30 valve everyone sells, they are junk. Willcox sells the good one.
Old Jun 26, 2016 | 10:49 AM
7T1vette's Avatar
7T1vette
No, it is not "normal" for the wiper door to do that....but it is NOT unusual for that to happen.
When it does, it's usually because of a bad check valve...and/or... a bad wiper blade safety switch (under right-hand wiper)...and/or... the steel tubing vacuum line (runs under the wiper motor across the firewall) having blockage at the low portion of the tubing.
The check valve and switch can be checked out before replacement; the cross-tube can be blown clear with compressed air (after removing tubing from both ends). The wiper safety switch can be misadjusted (up/down) because there is not enough 'slop' in the elongated holes, also. If that is the problem, open up those holes to get more travel.
Old Jun 26, 2016 | 02:52 PM
TheGreek!'s Avatar
TheGreek!
Thanks for the info. The check valve you mentioned, are you talking about that round metal deal with 3 vacuum lines (one line on one side and two on the other) that's located in the engine compartment that feeds vacuum to the headlights and the wiper door? If so then mine is most likely bad, you can blow through it from the engine vacuum side (the side of the valve with one vacuum port). I haven't checked the wiper safety switch or the metal vacuum line yet but I wouldn't be surprised if those are bad too (everything on this car seems to be bad).
Old Jun 26, 2016 | 03:05 PM
TheGreek!'s Avatar
TheGreek!
By the way, I found a check valve on e-bay and it also comes with a filter of some sort. I cant find that filter on my car anywhere so I'm assuming that it was removed at some point in the cars history. Where is the filter supposed to be installed? Does it go in the line that feeds the check valve? Here's the e-bay auction:
http://www.ebay.com/itm/1968-1982-Co...VRnabV&vxp=mtr
Old Jun 26, 2016 | 03:22 PM
71 Green 454's Avatar
71 Green 454
Should look like Alan's picture.
Alan 71's Avatar
Alan 71
Hi TG,
The small hose goes through the firewall and supplies vacuum to the 'control' side of the system while the large hose travels across the mater cylinder to a tee that has a short hose that leads to the vacuum storage tank and the large hose continues forward to the headlights..
Regards,
Alan
Old Jun 26, 2016 | 04:17 PM
TheGreek!'s Avatar
TheGreek!
Thanks for the pic, I just ordered the check valve/filter set from the ebay auction.
Old Jun 26, 2016 | 04:24 PM
TheGreek!'s Avatar
TheGreek!
Originally Posted by Alan 71
Hi TG,
Regards,
Alan
Thanks for the pic. I checked the vacuum hoses for the headlights and wiper door, all of them are routed correctly. I still need to check the function of the wiper blade safety switch and the metal line that 71vette mentioned but right now I'm busy working on the AC duct problem that I'm having in another thread, when it's finished I'll check the other stuff in the wiper door system.
Old Jun 27, 2016 | 08:25 PM
TheGreek!'s Avatar
TheGreek!
What's the matter with the 25-30 dollar valve, why are they junk?
Old Jun 27, 2016 | 09:53 PM
Dave J's Avatar
Dave J
To get the real answer, I guess the best place to answer that question would be the manufacturer. How about "Why don't your valves work, and why don't they hold up? My answer is simply, lack of tolerance standards, inferior base materials, and complete lack of understanding what the valve is supposed to do. When the manufacturer doesn't know how to properly test them, that's wrong.
Full disclosure here, I manufacture the valves Willcox sells. I have spent an inordinate amount of time and considerable expense to design a valve that would function as it should, and last for a long time. I had to fully research exactly what the valve was supposed to do, and when it was supposed to happen. I then diagnosed the issues the current valve had, and designed mine around all the faults. The bottom line is my valves work.
We put up with some real junk out there in the market place with the importers of our parts. The real fault lies with the retailers. If they want cheap parts, that's what they (and we) will get. I only hope my valves will help guys out who want their cars to function as they should.
OK, off the soap box.........
Here's some links to past threads for more information.
https://www.corvetteforum.com/forums...n-on-69-a.html
https://www.corvetteforum.com/forums...5638487-a.html
https://www.corvetteforum.com/forums...-question.html
Good luck with your car!
Old Jun 27, 2016 | 11:01 PM
TheGreek!'s Avatar
TheGreek!
Start the car, and if the "winking" went away, you found your problem. DO NOT replace it with the 25-$30 valve everyone sells, they are junk. Willcox sells the good one.
I went ahead and tested the wiper safety valve as per your instructions and the problem didn't change, the door still pops up on startup and then goes back down a second later. Do you think the problem is in the check valve that feeds the wiper and headlight system? If so I have a new one on order, hopefully it will be here soon. What else would cause the problem I'm having? I looked for the metal vacuum line that 71vette mentioned that runs behind the wiper motor and it's not there, my car doesnt have it.
Old Jun 27, 2016 | 11:21 PM
7T1vette's Avatar
7T1vette
If you have a vacuum operated wiper door, you have the vacuum transfer pipe. It connects the red striped vacuum line coming out of the firewall grommet on the driver's side (3 hoses in that grommet) to the red striped vacuum hose going into the 3-line grommet on the passenger side of the firewall. The hose coming out the driver's side is from the wiper vacuum solenoid/switch (behind tach) and the one on the other side goes to the wiper safety switch (under the right wiper blade).
No way for them to work if that metal tube (pipe) is not there. There is a "V" bend in the line below the wiper motor. That low spot is where 'stuff' can collect and partially block off that line. This can change the operating dynamics of the wiper door.
Old Jun 27, 2016 | 11:32 PM
TheGreek!'s Avatar
TheGreek!
I just went back and checked again and I can say with absolute certainty that there is NO metal line located behind the washer pump that connects the red striped vacuum hose that comes out of the 3 hose grommet on the drivers side to the red striped vacuum hose that goes to the 3 hose grommet by the wiper safety switch on the passenger side, it's one continuous vacuum line.
Old Jun 27, 2016 | 11:47 PM
Dave J's Avatar
Dave J
There is NO metal vacuum line on '69 cars, or for that matter, 1970. The metal line was added in 1971.
Old Jun 27, 2016 | 11:50 PM
TheGreek!'s Avatar
TheGreek!
Thanks for the info. Did you see post #13? What do you think the problem might be?
To Wiper door question
Old Jun 28, 2016 | 12:09 AM
Dave J's Avatar
Dave J
If the bypass test on the safety valve doesn't work, it could be any other component in the control circuit. The control circuit is the small vacuum line that ultimately switches the vacuum relay. From this point, no one can tell you exactly what the problem is, we are only speculating which component is failing.
The bottom line is the control circuit is lagging behind the actuating circuit. The reason is the control circuit is letting atmosphere into the line (leaking vacuum if you will), causing an imbalance. The culprit could be any one of these:
vacuum relay
safety valve
override switch
wiper door solenoid
headlight switch
check valve
any of the connected hoses
The proper way to repair the wiper door is to diagnose the problem. If you can get hold of a Mityvac (or equivalent) hand pump, or even a vacuum gauge, you can do it easily.
I can help you if you want. Let me know and I will give you my number.
Old Jun 28, 2016 | 01:20 AM
TheGreek!'s Avatar
TheGreek!
vacuum relay
safety valve
override switch
wiper door solenoid
headlight switch
check valve
I appreciate the help offer, I just might have to take you up on it if I can't find the problem. I'm going to track every hose and test every component until I find the vacuum leak in the control system, if I find the problem I'll definitely post what it is.
Old Jun 28, 2016 | 11:34 PM
BLUE1972's Avatar
BLUE1972
If you have a vacuum leak on a headlight vacuum actuator the wiper door will open, then close.. I just found the leak on the left headlight actuator - just started having that wiper door problem and found the leak.
I have A/C so it's a PIA to replace.. hoping to do it this winter if the leak doesn't get worse...
