Disappointed
If a 218-224 is too small and revs to 5500 or so.
How does adding 6* of intake make it rev to 6300?
I would think it would add 200-300 rpm to HP peak?
Shows what I don't know.
I'm still running the restrictive 2" RHs.
I can't wait to see what the 2.5" RHs will make?
R
So to answer you question....yes because of the AFR's high I/E ratio the duration at .050" is best if the same. The 224 with 1.6 would be best for a 350 wanting peak power around 6300 rpm.
l dont think that going from 218* to 224* will raise peak to 6300. When I had the 400" out at the strip I started shifting at 6200 to dodge pesky valve float that can occur with hydraulic rollers around 6300 when your using cheapo street hydraulic roller set, when i say cheap the lifters alone were $450 and with afr 195's and a hydraulic roller and rpm air gap, i could feel were it fell flat on its face, i backed the the rpm down 200 rpm and the et/mph picked up until I hit 5700 rpm on the tattle tail light which ment the shift light came on at 5500 rpm, it stayed the same between 5600 and 5700 rpm. The cam is advertised to 6300 rpm.
Last edited by bluedawg; Jul 20, 2016 at 12:52 PM. Reason: Because I was drunk when I finished this post.
head flow:
.200 .300 .400 .500 .550 .600 .650 .700
Int 148 210 261 296 304 312 315 318
Exh 114 162 204 220 225 229 233 237
Last night I took it out to one of the local out of the way steep hills, and ran it to 5000 plus in every gear but 4th. Did it multiple times going up hill, and did strong engine braking multiple times downhill.
In 4th gear, this engine was still pulling strong, and car accelerating as is approached very high mph (going up hill), and not yet to 5500 RPM. It felt like there was still much more there, but it was as much as I was willing to do......admittedly, I am a chicken, and it was scaring me! I also was running out of straight road and trying to drive an keep an eye on the tach and speedometer, etc....it was fast enough for me to see what this motor can do.
Once I floored it, it was like a rocket boost lit off, and I am assuming that was the secondaries coming in! It was a solid and sudden boost that launched the car, with a slight turning tendency (not sure why or if that is indicative of anything wrong)??? The throttle response, and power, felt smooth without any noticeable hesitation or bog from idle to 5500.
I can see now that while the world below 3500 RPM is actually still strong, as many of you stated, the power really comes in above that. With the four speed, it is available to me when I want it. I like it!
So, thanks to you all. I am happy with the engine. If I was at the beginning again, I might still go 383, just to have more torque down low. Its not in my nature to push an engine to high RPM...I always feel like I am abusing it, and I have never had enough money to abuse my hard earned possessions. But the whole point was just knowing the power is there and I built the right engine. And last night, I found out the power is there to play with when I want to.
I still want to get it on a dyno to get the numbers, and tweak whatever needs tweaked. I have never heard one sign of detonation, so either my timing is right on, or I have more available....!
http://www.livernoismotorsports.com/
Woohoo! It's about time. As for being scared. That's a good thing. My dad told me way back when I was learning to race cars that if most people knew what their cars were capable of, they would sell them because they would be so scared. This applies to most any sports car. I drive particularly nice when I have passengers and sometimes they still get scared. When I have another person like my father with me or I'm solo, look the heck out. And there have been a few times I've tried to teach my son not to be such a scared putz behind the wheel, but he is still learning.
I got my GM 350 crate engine yesterday. I'm going to tear it apart and modify it to make decent power, and you can rest assured I will use it accordingly. Horsepower and torque are equal at 5252 rpm by definition. HP is definitely a function of time, so things don't really begin to happen until the upper rpm range as far as acceleration goes anyway. Some engines have to be really revved in order to do anything. A 350 is a nice mix of mid range torque and HP which is why you car is really coming alive at 3,500 rpm. That sounds about right for a V8. Wait until you get used to it and start shifting hard at the 5,800 to 6,000 rpm range.
Adam
http://trust-me-im-an-engineer.kinja...rpm-1650651680
I remember from Physics class how Watt came up with the HP with a horse pulling a weight attached to a rope and a pulley a certain distance in a certain time, but didn't really understand it's application to engine torque and hp relationships and why that cross always happens on the dyno chart where it does.
Mind blown!
Awesome stuff.
Adam
I was thinking back to when my motor was 4.125X4.00 with everything else equal. I can't remember a big drop off. It seemed to power right into 7500 rpm. The local track is 4.3 miles around and I was shifting near the rev limiter in 3 & 4th several times per lap. Then my crankshaft broke so i bored it and reset my rev limiter to 7000 to make it last longer
You are right about header size. A smarter person would buy spread port Gen 1 heads and just have some custom 2.00 inch headers made
Now get yourself an AEM 02 kit from Summit install before hitting the dyno, bet theres more to be found with fine tuning.
now dont you pity all those who only baby their cars they dont know what they are missing. Get your fun in, one day someone will fire sale it not appreciating what youve done to it. Best mindless activity on the planet! When you find you cant look at the tach or speedo its running good.
