Disappointed
650 DP Carb
Performer rpm intake
Stock OEM late model GM 350 Heads with stock valve size (Cast Iron) No Port work.
Stock 1.260" OD Valve spring
Stock OEM 1.5 Ratio Rockers
Hyd roller camshaft .460/470 210/215 110 LSA
Cast Flat top piston 4 valve reliefs.
.020" Shim Head gasket
5.7" OEM Stock rods with ARP bolts
Stock OEM Cast Crank
I have supplied parts for over 60 of these. They make between 360/370HP and 380/390#ft with basically OEM parts and up graded camshaft. The OP's build is very capable of making 400HP base on the parts he has.
1977 Corvette L48 specifications show the engine to be 180 HP....is that engine or rear wheel horsepower? I believe whatever it is, it includes all accessories i.e. smog pump, alternator, etc. This is why early C3 Corvettes appear to have higher HP ratings than later model C3 Corvettes because the factory showed early numbers WITHOUT any accessories, and then at some point, like in 73 or 74 the numbers included all accessies belted up. Yes, I know, late model smog equipped cars with catalytic converters do have lower HP numbers, but not the dramatic difference it appears to be due to the above stated. (Reference Tom Falconer Original Corvette book).
Now, if people are going to state HP values, please clarify if we are talking engine HP or chassis rear wheel HP.... I would think it makes a difference. My naïve viewpoint is that when I / we are talking 400 HP, we are talking engine HP, not rear wheel.
Gross=hp and torque at the crank, no accessories,1 no drive train, just the engine, no air cleaner, dyno headers or exhaust.
Net= hp and tq with accessories attached such as ps pump, alternator, water pump, air cleaner, smog pump and stock exhaust.
Rwhp= power exhibited through the drive train at the rear tire.
Here's were I get confused, i have a 78 manual kinda like a Chilton that says the 180 horse was through the tranny, others say this isn't the case, I don't know for sure.
This thing should have plenty of grunt. I feel you have a fuel or ignition issue that is making it lazy. I would check and recheck all fuel and ignition stuff.
I cam for average power under the curve. Camming to make peak power at 6500 rpm then you drive the car at an average of 3500 is not going to be a good running street car.
So to answer you question....yes because of the AFR's high I/E ratio the duration at .050" is best if the same. The 224 with 1.6 would be best for a 350 wanting peak power around 6300 rpm.
I have a calculator on my web site based on some of Chris's writtings
Estimate Cam Intake Duration @ 0.050" Needed
Engine Size = 540ci -- Number of Cylinders = 8 -- Max RPM = 6000
Volumetric Efficiency = 100% -- Head Flow - Intake CFM = 324.52
The result of your calculation is:
260 Duration @ 0.050" Lift
Special Thanks to Chris Straub - Straub Technologies
Stan
__________________
Stan Weiss / World Wide Enterprises
Do you use engine simulation software that uses cylinder head flow files?
We have a package of more than 2950 DFW or FLW Files.
http://www.erols.com/srweiss/index.html
Offering Performance Software Since 1987
Interested to see how you feel after the next drive or two !?
These Chevrolet Performance ZZ4 350 C.I.D. 355 hp turn key crate engines include all of the necessary parts to get your engine running. With over 405 ft.-lbs. of torque, the ZZ4s are the best way to put an aluminum head, 4-bolt main block, roller cam, high performance small block between your favorite fenders. The aluminum angle-plug cylinder heads have screw-in rocker studs, 1.94 in. intake and 1.50 in. exhaust valves, and 58cc combustion chambers that yield a crisp and responsive 10:1 compression ratio. Also included are lightweight valve spring retainers, radiused valve seats, and valve stem seals to help keep the oil where it belongs. To complement the cylinder head design, we've incorporated a billet steel hydraulic roller tappet camshaft with a .474 in. intake and .510 in. exhaust valve lift. The combination makes 355 hp at 5,250 rpm and has that great-sounding musclecar idle, with just enough lope to let people know that these are no station wagon engines.
Additional features include:
* HEI distributor with an ignition timing advance curve developed for performance
* Spark plugs and wire set
* Dual-plane aluminum intake manifold
* Holley 770 cfm carburetor
* Chrome air cleaner kit
* Fuel pump
* 8 in. harmonic balancer
* 12.75 in. automatic transmission flexplate
* Starter
* Cast iron water pump
* Serpentine accessory drive pulley system for air-conditioned applications
Even though the engine will probably run the strongest above 3000 rpm, you should have plenty of torque at lower RPM to have some fun with. The one thing I can see with your setup while running below 3500 RPM is with the Quadrajet you may still be on only the primary side of the carb, which has a very small CFM rating with double or triple venturies (can't remember anymore), for good gas milage and not performance. You may not see the engines real potential until you get those large secondaries to open up. Use to run a Quadrajet on a BB Olds engine years ago, and when those large secondaries would kick in you could definitely feel it.
Just for comparison. You have larger heads and I have a bit larger camshaft:
- New GM ZZ4 short block
Same
- AFR 180cc Heads, 65cc Chamber 10:1 Compression (015 gasket)
ZZ4 (L98) Heads, 165cc, 58cc Chamber, Manley Race Flow Valves & Springs
- GM Factory Hydraulic Roller Lifter system
Same with AFR "rev kit"
- Comp Cam Extreme Energy XR270 Roller Cam (218/224, .500 lift, 110 LSA)
GM's LT4 "Hot Cam" (218/228, .525 lift, 112 LSA)
- Comp Cam Ultra Pro Magnum Steel Roller Rockers
Crower 1.6 Roller Rockers
- Edelbrock RPM intake
ZZ4 dual plane intake with 1/2" 4-hole spacer
- Quadrajet rebuilt by Lars (with the above engine specs)
Demon (Holley style) mechanical 4 barrel
- DUI Performance HEI Distributor (timed to 35 degrees)
GM HEI with MSD coil, recurved, and adjustable vacuum advance
- Stainless Works 1-5/8 inch long tube headers / 2-1/2 mandrel bent exhaust system
1-5/8 long tube headers and dual exhaust
- Borg T-10 Rebuilt Original 4-speed transmission with 3:55 differential; New Spec Stage II Clutch
Richmond 5 speed transmission, aluminum flywheel, dual friction clutch, 3.08 gear
Here is my chassis dyno pull (328 RWHP & 350 Tq). Blue line I was running lean so I quite early and rejetted the carb. Everybody disagrees with what exactly chassis dyno numbers mean since different brands/operators will produce different numbers, but they are great tuning tools so I definitely recommend spending some time on one.
It has more torque above 3k, but even at 2k the torque isn't horrible so if your engine is anything like mine it should be fun to drive. Important thing is it took some tuning on the carb and ignition to get the engine to run good. At first it was a bit lazy too.
Also, here is my 1/4 mile running on true street tires. Not extremely fast, but it can hold its own against most street cars. I have no complaints about its performance and I built this engine ~15 years ago. Note that to achieve this time I shift at 6500 rpm and the engine doesn't drop below 3000 rpm during the run.
60' 1.922
330' 5.381
1/8 8.27 @ 85.5 mph
1000' 10.744
1/4 12.8 @108 mph
Good luck getting her tuned correctly, your setup should be fun to drive when you get it sorted out.
Trying to find a camshaft for your LS-Series based engine? Livernois Motorsports has a cam for your application.
Livernois Motorsports Stage 2 LS-Series camshaft is recommended for mild street vehicles. It works excellent with our CNC cylinder heads and produces good power while still maintaining a decent idle and good drivability.
Duration 232@.050
Lift .595"
LSA 114
http://www.livernoismotorsports.com/
60' 1.922
330' 5.381
1/8 8.27 @ 85.5 mph
1000' 10.744
1/4 12.8 @108 mph
1977 Corvette L48 specifications show the engine to be 180 HP....so is that engine or rear wheel horsepower? I believe whatever it is, it includes all accessories i.e. smog pump, alternator, etc. This is one reason why early C3 Corvettes appear to have higher HP ratings than later model C3 Corvettes because the factory showed early numbers WITHOUT any accessories, and then at some point, like in 73 or 74 the numbers included all accessies belted up. Yes, I know, late model smog equipped cars with catalytic converters do have lower HP numbers, but not the dramatic difference it appears to be due to the above stated. (Reference Tom Falconer Original Corvette book).
Now, if people are going to state HP values, please clarify if we are talking engine HP or chassis rear wheel HP.... I would think it makes a difference. Its important that we are comparing apples with apples, and not oranges.
My naïve viewpoint is that when I / we are talking 400 HP, we are talking engine HP, not rear wheel. If I am correct and we are comparing apples with applies, my engine at 350 - 400 HP, original L48 at 180....I would think I should feel twice as much HP. But, I don't.....! And that's what started this thread.
Of course, let me get the car out there and get it tached up like you are all suggesting. Got to fix my transmission aft seal leak first.
So, my 1977 Corvette advertised 180 HP as an L48 option. If I am to believe the majority of people who I respect on this forum, if I believe the desktop dynos I have entered components in to, and if I believe everything I have read in many books on the expected HP and Torque I should get out of the components I have chosen, IF I produce 360 HP, I have doubled it! If it makes 400 HP like many believe, its impressive, and a great improvement over stock. Arbitrary numbers really mean very little to me, even though the American white boy in me likes to hear big numbers.
Another chest thumper....HAHAHA. I looked at it the same way you do when I did.top end on the L48, if you make 280 horse at the drive shaft yoke, then you've respectfully added a soldI'd 100 horse if to hit 400 gross, that would put you in the 330ish at the drive shaft yoke, that's putting 150 more horse out, very respectable and you shouldn't have any issues noticing 120 to 150 more horse. Now would you quit talking, get out and punish that f***er some so we can you can spot that extra power.
Duration 232@.050
Lift .595"
LSA 114
If a 218-224 is too small and revs to 5500 or so.
How does adding 6* of intake make it rev to 6300?
I would think it would add 200-300 rpm to HP peak?
Shows what I don't know.
I'm still running the restrictive 2" RHs.
I can't wait to see what the 2.5" RHs will make?
R
head flow:
.200 .300 .400 .500 .550 .600 .650 .700
Int 148 210 261 296 304 312 315 318
Exh 114 162 204 220 225 229 233 237
