Light switch knob pulled completely out
Old Jul 12, 2016 | 10:34 AM
Surfer69's Avatar
Surfer69
Default Light switch **** pulled completely out
Can't remember if that means switch is no good or it's still OK and I just need to be carefull on how far/hard I pull?
Old Jul 12, 2016 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Switch might be operable, but the rod detent is gone. Can you get the headlights on without the detent?
Old Jul 12, 2016 | 04:54 PM
Surfer69's Avatar
Surfer69
Havent tried yet.
Was on the way to work this morning when it happened. Stuck it back in and lights went out and doors went down so I know at least that still works right.
Old Jul 12, 2016 | 05:56 PM
Alan 71's Avatar
Alan 71
Hi S,
There's a small 'spring loaded' button on the bottom of the switch that's pushed to release the ****/rod.
Perhaps this has failed, but you MIGHT be able to get it to work again if you can get access to it.
Good Luck!
Regards,
Alan
Old Jul 13, 2016 | 10:05 AM
Surfer69's Avatar
Surfer69
So seems to work fine and normal. Guess I will leave it alone.
Aint broke dont fix.....
To Light switch knob pulled completely out
