Headers or No headers
Old Aug 5, 2016 | 09:28 PM
Blondie - C3's Avatar
Blondie - C3
Default Headers or No headers
My friend says I should install headers on my 81 c3 that only has 190 hp
Is it a lot of work
Is it costly
Is it worth it
Old Aug 5, 2016 | 10:07 PM
Blondie - C3
Default Sorry
Originally Posted by Higgs Boson
you're 35 years off. try the C3 section.
Sorry. Still learning the site.
Old Aug 6, 2016 | 12:07 AM
superramvette2's Avatar
superramvette2
Do it!
Old Aug 6, 2016 | 04:00 PM
terry82's Avatar
terry82
Is it a lot of work
Is it costly
Is it worth it
what do you want from headers?do you like loud exhaust?how much do you want to spend?do you like factory original?
Old Aug 6, 2016 | 04:19 PM
Morgdve's Avatar
Morgdve
St. Jude Donor '16,'24
Your '81 has what the factory called "stainless steel tubular exhaust headers". My guess, without some semi-major work on carb, heads, cam and mufflers/cats, your car won't "see" much improvement with aftermarket headers only. (i.e. too many restrictions upstream and down stream from the exhaust manifolds to realize any real gains on a stock engine)
(If you had had an older car with cast iron exhaust manifolds, its a little different)
Old Aug 6, 2016 | 07:14 PM
lars's Avatar
lars
Is it a lot of work
Is it costly
Is it worth it
Yes
Yes
Not on an otherwise stock '81
I wouldn't do it. In order to get a seat-of-the-pants performance improvement in a car as heavy as your '81, you need to gain at least 20 hp. You will not gain 20 hp by replacing your stock tubular manifolds with headers, so you're going to spend a ton of effort, frustration, modification, and money for something that you'll notice no actual improvement from if this is the only mod you do.
Lars
Old Aug 7, 2016 | 12:06 AM
bluedawg's Avatar
bluedawg
Is it a lot of work
Is it costly
Is it worth it
Medium work, it took me 4 hours with a lift and I took it to an exhaust shop for the exhaust and mufflers.
Low cost, $1400 for decent headers and duals with mufflers.
Way worth it, awesome sound and deffinant sound gain.
My $.02 any way.
Old Aug 7, 2016 | 09:09 AM
redwingvette's Avatar
redwingvette
I went another way:
Speedway Motors 2-1/2" Rams Horn Manifolds.
Old Aug 7, 2016 | 04:10 PM
centuryoldracer's Avatar
centuryoldracer
Originally Posted by lars
Yes
Yes
Lars
Best bang for the buck is a small nitrous system. Hours O fun, and pretty easy to install.
Old Aug 7, 2016 | 04:26 PM
76vette1's Avatar
76vette1
Originally Posted by redwingvette
I went another way:
I took the headers off and put these manifolds on. Reduced the engine compartment heat significantly without harming performance.
Old Aug 10, 2016 | 07:54 PM
Blondie - C3
Thank You everyone for your input. I have decided to leave well enough alone. It's a great touring vehicle and I'll stick with that. No need to open Pandora's box on a car that is solid right now.
Old Aug 11, 2016 | 10:09 AM
7T1vette's Avatar
7T1vette
Much better 'bang for the buck' if you just tune up the carb and re-curve the distributor timing for performance. This low-dollar effort will net you as much improvement as thost $1400 headers. You also need to verify that the carbs secondary throttle plates are completely vertical when the ACCELERATOR PEDAL is fully depressed (rather than exercising the throttle linkage by hand).
Old Aug 11, 2016 | 03:12 PM
lvmyvt76's Avatar
lvmyvt76
I agree, a lot of money for not much extra, with a stock engine. I have them with a new dual exhaust, no signficate incress in power, but I have one of the lowest HP motors out there.
Old Aug 11, 2016 | 07:11 PM
fishslayer143's Avatar
fishslayer143
Yes
Yes
Lars
I could not have said it beer
Old Aug 11, 2016 | 07:43 PM
jb78L-82's Avatar
jb78L-82
I used shorty headers for years on my 78 L-82 since I was not convinced that all the effort and time was worth LTH's. With the new L-82 355 with roller cam and AFR heads now that is a different story. Still trying to find time to install my XSPower headers that are 1 3/4 inch primaries and 3 inch collectors (actual dimensions) which should net a BIG increase in power over the shorty headers with 1 5/8 inch short primaries and 2 inch collector (stock replacement) with the AFR's and roller cam:
http://shop.huronspeedproducts.com/X...rs-c2c3hug.htm
To Headers or No headers
