In-line fuel filter.
There wasnt much left to the fuel system on my 73 when I got it. Piecing it back together, the only fuel filter is the small inlet filter in the carb. (qjet). Other than the pick-up screen in the tank, was there anything else? I've seen some canister type filters spliced in the fuel line up by the engine on some of the older big blocks. Was wonder if I should put one in, if so, what's a good one to use. I have this older frame rail filter from a mid 90's suburban. The size is about right but I dont think the fittings will work. Suggestions?
Received 2,878 Likes
Hi 73,
No, originally there were just the 2 you mention. The sock on the sender in the tank and the filter built into the q-jet.
Is there a situation that's making you feel you need something else?
Regards,
Alan
Regards,
Alan
73BBVette (08-19-2016)
The Qjet fuel filter is all you need, but if you want to fabricate an inline filter, here is an article by Lars on how to build one.
I'm in the process of fabricating an inline fuel filter on my '71 BB. I'm using a new steel fuel line, a Summit fuel filter and fittings. These are AN fittings and require a 37 degree flare on the fuel line.
Lars instructions:
https://www.google.com/url?sa=i&url=...r4kDegUIARC2AQ
My plan:
Should look like this:
Lars instructions:
My plan:
Thanks 71, I'll check Summit's web site for that. That looks like a clean install too from the picture above. Alan, no situation as I haven't fired the engine yet. But looking at a lot of under hood pictures, I see a lot of them installed, even factory AC filters. Just wondering if it was needed or not. Considering that there wasn't any thing else originally on the car, maybe I'll rethink this a while.....
Received 1,470 Likes
Cruise-In II Veteran
I did the same as 71 Green, using Russells 6 AN fittings and filter purchased from Summit. No interference behind A/C front mounting bracket and head. filter is 40 micron(?). I have this mounted to a holley 4175 carb. I do plan going back to QJ rochester but will leave the fuel line. my .02 cents.
Mike
Mike
Hi 71,
The return line would be a pipe running off the bottom of the fuel pump.
Have you checked to see if there's one there?
Regards,
Alan
This is the typical return line.
Regards,
Alan
A return line from the fuel pump back to the fuel tank? Yes, I have that plumbed already.
I thought he was asking about a line that would attach to the filter, like the second one on the top.
https://www.google.com/search?q=1973...lhxwDf-oVtM%3A
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,927 Likes
There is no good reason to install an in-line filter if you have a street car with the in-carb Q-Jet filter. If you want an in-line filter for the looks, be sure to remove the in-carb filter - running 2 filters will cause fuel flow problems, so just run one or the other. Especially bad is running a fliter on the suction side of a mechanical diaphragm pump, such as back by the tank. That will induce vapor lock issues and fuel starvation at high rpm - only use a filter on the pressure side of the pump.
The in-carb filter actually flows pretty good, and the paper element is the same element that a lot of the aftermarket in-line filters use inside their aluminum housings - you would be replacing the in-carb filter for exactly the same filter in an in-line housing, with a bunch of work to make it work. Not sure there's much of a point to that...
Lars
Lars
