Center panel between t-tops.
Old Aug 30, 2016 | 06:38 PM
rayluka's Avatar
rayluka
Default Center panel between t-tops.
I purchased a new center piece for the roof in between the t's. How is this attached? It has 3 threaded studs. I removed the metal trim and you cant access the threaded part. How did they originally connect. Is their something missing. Otherwise I will drill holes and put washers and nuts on it and put the chrome back on and be done with it..Also on another note it never was in properly when I bought the car.
Old Aug 30, 2016 | 06:49 PM
Alan 71's Avatar
Alan 71
Hi r,
On the underside of the trim panel are studs with 'teeth' on them.
Attached to the birdcage there were originally flat fasteners with a hole in them which a tab that grabs the 'teeth' on the stud. Those flat fasteners were attached to the cage with 2 rivets each.
You position the trim piece and then give it a gentle but firm 'smack' with the butt of your hand which 'set's those studs in the flat fasteners.
Good Luck!
Regards,
Alan
Old Aug 31, 2016 | 03:39 AM
rayluka's Avatar
rayluka
Originally Posted by Alan 71
Hi r,
Good Luck!
Regards,
Alan
Now to find this elusive part you speak of...Thanks for the help pointing me in the right direction..
Old Aug 31, 2016 | 05:07 AM
7T1vette's Avatar
7T1vette
If you have a 'vintage' piece (something over 30 years old), you want to be very careful how you install it. If you 'pop' it as Alan71 recommends (proper method for a relatively new piece), it can crack or shatter. After many years, interior plastic parts become brittle. When applying pressure to them, that pressure has to be distributed across the part to minimize localized stresses.
To Center panel between t-tops.
