Q jet EFI
Old Oct 9, 2016 | 10:58 AM
TNT's Avatar
TNT
Default Q jet EFI
Anyone make a throttle body the replaces a Q jet. Spread bore. No adaptor plate. All I have found are ones that replace the Holley square bore carbs.
Thanks Thad
Old Oct 9, 2016 | 05:39 PM
Shark Racer's Avatar
Shark Racer
None that I'm aware of. I went from Q-Jet to TB EFI on a ZZ4 intake.
Old Oct 10, 2016 | 10:36 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
The fitech will bolt onto a quadrajet intake, but I think they recommend still using an adaptor for better flow?
Old Oct 11, 2016 | 12:48 PM
Shark Racer
It will bolt onto a factory Q-Jet intake? I'm skeptical...
If it's like a regular square bore carb, the bolts won't line up and you'll get significant interference on the primary throttle blades.
Old Oct 11, 2016 | 04:10 PM
7T1vette's Avatar
7T1vette
Just contact the EFI manufacturer to see if they make one to replace the Q-jet. Since almost ALL GM cars made between 1965 and 1980 had Q-jets on them, I would be amazed if they didn't have the unit you need.
Old Oct 11, 2016 | 05:00 PM
Shark Racer
What's really interesting is that MSD Atomic EFI is a CARB legal system for GM cars that had a Q-Jet (electronic or mechanical) from the factory. Yet, there aren't any E.O.'d dual pattern intakes... which means the CARB approved these MSD kit on an "illegal" intake.
Old Oct 11, 2016 | 06:54 PM
shok's Avatar
shok
I thought it was approved while mounted to the stock intake?
Old Oct 11, 2016 | 07:04 PM
Shark Racer
It'd need an adapter to fit the stock intake.
There're probably at least a few cars in the "all GM cars with a QuadraJet" group that could fit that throttle body and adapter, but Corvettes certainly aren't one of them.
Old Oct 11, 2016 | 07:05 PM
shok's Avatar
shok
Oh gotcha. I've been bouncing the idea of getting that kit in my head for awhile.
Old Oct 11, 2016 | 07:07 PM
Shark Racer
https://arb.ca.gov/msprog/aftermkt/devices/eo/D-722.pdf
It was tested on a Chevy Impala:
Old Oct 11, 2016 | 07:08 PM
Shark Racer
I like mine so far. Are you near me? (Santa Clara)
Old Oct 11, 2016 | 07:11 PM
shok's Avatar
shok
I'm in Salinas, so not too far. Plus I work in Mountain View, haven't driven the Vette to work yet though, working up to that part
Old Oct 11, 2016 | 07:13 PM
theandies's Avatar
theandies
Sucks to live in Kalifornia.
Old Oct 11, 2016 | 07:48 PM
Metalhead140
It has holes to suit both. Bottom of the page here:
"Note that the Fitech throttle body will bolt directly to a spread bore 4-BBL manifold but may leak without the adapter plate."
You can sort of see the mounting holes here:
No idea about the throttle blades though. They may well be the reason for suggesting an adapter plate is needed.
Old Oct 11, 2016 | 08:17 PM
Shark Racer
Thanks! I thought they might have done that, but I couldn't imagine how the throttle blades would have worked.
Old Oct 11, 2016 | 08:30 PM
Metalhead140
Maybe the throttle blades are higher in the throttle body, allowing them to clear? Or maybe not, and it actually does need the adapter (the wording in the instructions makes me wonder if it's actually needed or if they're just covering themselves). If I have it off the engine again then I'll have a look to satisfy my curiosity.
Edit: Looking at the 1st manifold you pictured, the gasket provided wouldn't seal between the holes (it's an open square gasket) and so wouldn't seal that manifold around the front of the carb/throttle body. It possibly might seal to the 2nd manifold, hard to know without comparing in person.
Old Oct 11, 2016 | 11:26 PM
7T1vette's Avatar
7T1vette
This is all conjecture. Contact the manufacturer...if you really want to know what's up with the spreadbore manifold situation. Otherwise, talk on.....
To Q jet EFI
Old Oct 11, 2016 | 11:32 PM
Metalhead140
I don't care, I'm not using it with a spreadbore. Just trying to help the op?
Old Oct 12, 2016 | 12:05 AM
Shark Racer
I, personally, appreciated your pictures and info.
One thing is for sure - without a dual pattern manifold, there will be problems with the throttle blades. Either they design them to fit both styles and the primaries are spread-bore sized and recessed, or they are square-bore sized, recessed, and you get fairly significant turbulence as the inbound air charge slams into the smaller opening at the intake manifold.
Old Oct 12, 2016 | 12:38 AM
Metalhead140
Agreed. And all throttle blades are the same size. It's definitely going to work better on a square bore manifold. I expect it would work fine on a dual pattern intake.
