How Does This Work?
Old Oct 13, 2016 | 12:30 AM
Cavu2u's Avatar
Cavu2u
Default How Does This Work?
I want to pull this.
The tool I'm told by the manual to use is this. J-23072
I'm looking at this.
Does the 4-hole plate here have something to do with it?
Just stupid I guess.
Thanks in advance.
Steve
Old Oct 13, 2016 | 12:19 PM
7T1vette's Avatar
7T1vette
There is a [wire] snapring holding the housing onto the column. Remove it and the 4-hole plate should come off.
And, there is a BIG difference between being "stupid" and being "uninformed". You are intelligent enough to ask the right questions....
Old Oct 13, 2016 | 05:21 PM
Cavu2u's Avatar
Cavu2u
Default Bubba
I found I could remove it by,
a) suspending (holding by cupped fingers) the whole assembly by the bottom of the bowl and having an assistant hit the center tube (protected with a PVC pipe adapter) with a large hammer, and
b) once the tube's top is flush with the bowl, the bottom of the bowl can be pried up and off the tube with a Yankee screwdriver, using the conveniently placed slots in the outer tube.
As stated in a previous thread I found, the bowl isn't on the tube very tight.
And did I state the column was apart before?
Thanks Bubba!
Steve
To How Does This Work?
