12 bolt conversion
Old Apr 21, 2019 | 05:22 PM
  #261
jd1a's Avatar
jd1a
Keep the diff from moving during an axle event?
Old Apr 21, 2019 | 06:21 PM
  #262
rpoL98's Avatar
rpoL98
Originally Posted by JohnRR
I haven't seen this before. Can you please explain the purpose of this differential brace? Mechanically, what does it do?
JIMHO, looks like it braces the diff against the strong part of the frame. otherwise diff pushes against cross member, cross member would deflect forward. these braces look like they transfer the load to the outside corners, instead of the center of the cross member. the center of the stock cross member is not braced diagonally against the frame.
I'm just wondering if the nicely machined brackets holding the rod ends are steel, or aluminum. I'm guessing steel, but they're so shiny and bright, could be aluminum.
Old Apr 21, 2019 | 06:22 PM
  #263
76strokervette's Avatar
76strokervette
The idea is to eliminate side to side and up and down movement. Also provide a little pinion angle adjustment mechanically with the struts.
It should make the center section act as part of the chassis as well. I am going to weld in the crossmember brackets then get ready to test.
There is a lot of movement with the factory mount and frame flex.
Old Apr 21, 2019 | 06:26 PM
  #264
rpoL98's Avatar
rpoL98
Originally Posted by 76strokervette
I am going to weld in the crossmember brackets...
I guess then they're steel. which is good. nicely done.
  #265
76strokervette
Here is video of a cool build and it also shows the frame flex at 7:41 in the video.
Old Apr 21, 2019 | 06:31 PM
  #266
76strokervette
Brackets are steel, struts and rod ends are chromemoly. The rod ends are rated to 26400 lb pull strength.
Old Apr 22, 2019 | 01:35 AM
  #267
rpoL98's Avatar
rpoL98
I like the idea of welding the rod end bracket to the frame. but, since it will be welded to the frame, could you use an off-the-shelf steel rod end bracket, found in the chassis fabrication vendors catalogs? similar to the RideTech bracket, not saying this particular one would fit, but something like it?
ETA: obviously, I'm very interested...
Old Apr 27, 2019 | 07:06 AM
  #268
76strokervette
The frame bracket I machined uses exiting bolts for location and is much heavier then the part in your picture.
I know many on here have excellent fabricating skills and can weld but many cannot. The brackets can be installed by anyone
and professionally welded for those without that skill. I hope that answers your question.
Dave
Old Apr 28, 2019 | 10:28 PM
  #269
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Some of Dave's handiwork put to good use finally!!!!!!
Old Apr 28, 2019 | 10:31 PM
  #270
rpoL98's Avatar
rpoL98
Dave
got it. agreed. good point.
Old Jun 1, 2019 | 07:48 AM
  #271
76strokervette
Just received my custom made chromoly driveshaft.
Old Jun 1, 2019 | 07:19 PM
  #272
rpoL98's Avatar
rpoL98
looks nice. I'll bet close up, it's a work of art, almost too pretty to expose to road elements. did the trans yoke (w/straps) come with it? just wondering.
Old Jun 2, 2019 | 04:17 PM
  #273
76strokervette
Driveshaft is in and I did a little detail work on some of the components while in there.
Old Jun 2, 2019 | 04:22 PM
  #274
76strokervette
Slip yoke is the stock piece. As you will see in the pictures I replaced straps with chromoly caps.
Old Jun 2, 2019 | 07:12 PM
  #275
69ttop502's Avatar
69ttop502
Nice David!
Old Jun 2, 2019 | 08:09 PM
  #276
MattoonVette
Looks great Dave!!!!
I just got my driveshaft too and installed it today. I am sure you recognize what’s in the picture.
Old Jun 2, 2019 | 08:18 PM
  #277
76strokervette
Thanks Bill. Have you put in any seat time yet?
To 12 bolt conversion
Old Jun 3, 2019 | 12:27 AM
  #278
OldCarBum's Avatar
OldCarBum
Is that a G Force cross member in the photo?
If so, how did everything bolt up?
Old Jun 3, 2019 | 08:02 AM
  #279
MattoonVette
Yes sir it is. It was a bolt in except for the fact that I originally bought it for the T-350 transmission but ended up going with a 4L60E transmission. Even then, all I had to do was shorten the tab where the transmission mount bolts on. Otherwise it would had been a direct bolt in for the T-350. They do make one for the 700R4 and 4L60E which is a direct bolt in.
Old Jun 3, 2019 | 08:07 AM
  #280
69ttop502's Avatar
69ttop502
Not yet David. Picking the car up in a week or so, then need some assembly lol! Have you driven yours yet. Any thoughts on the differential struts?
