Help
Old Nov 3, 2016 | 03:49 PM
calvette 11's Avatar
calvette 11
Default Help
Has anyone here done business with a company in Boynton Beach Fla. Called
Corvette Parts online. They sell rear ends
+I would like some feed back.
I think I have been had
Callahan
Old Nov 3, 2016 | 04:03 PM
MelWff's Avatar
MelWff
i just googled "corvette parts online" and came up with nothing. Do you have a link to the company?
Old Nov 3, 2016 | 05:59 PM
calvette 11
Default here it is
We carry a full range of corvette differentials
and suspension from complete differentials and
parts to new complete Trailing Arm Assemblies.
Complete Remanufactured 1963-79 corvette
differentials with New Ring & Pinion, Timken
bearings, CR seals, Eaton clutch pack, New side
stub axles and a GM cover.
$1495.00 freight free, no core charge.
No core charge for the above unit, we will buy
your old core - value will be between $100.00 to
$400.00 depending on condition, the exterior
must have no damage or apparent defects.
Freight is the customer's responsibility.
(1963-1979 Left Photo)
Re manufactured Differential with a New CNC
Pre-lapped Gear Set, Eaton Clutch Pack, Posi
Cross Shaft and Retaining Screw, Timken
Bearings (6), CR Seals (3), Shims, Crush Sleeve,
Ring Gear Bolts, Pinion Nut. 5 year warranty
that includes no gear noise.
$799.00 with core in.
TECH NOTE: There are 2 different size pinion yokes
Available in 3:08, 3.23, 3:36, 3:55, 3:73, 3.90, 4:11,
4:33 and 4.56 gear ratios.
For returning core later call for core charge.
New NITRO Positraction with 800 lb Springs and
Carbon Fiber Clutches $537.00
NEW Bare EATON Positraction Cases 1963-79
3-Series 2.72-3.90 $210.00
4-Series 4.10 & Up $210.00
NEW EATON Complete Positractions
3-Series 2.72-3.90 $568.00 (All Thick gears any
ratio)
4-Series 4.10 & Up $568.00 (for thin ring gears)
AUBURN PRO Positractions 1963-1979
3-Series 2.72-3.90 $499.00
4-Series 4.10 & Up $499.00
This Auburn is a Heavy Duty unit.
1980-1982
Re manufactured Differential with New Gear Set,
Dana Clutch Pack, Posi Cross Shaft, Timken
Bearings (6), CR Seals (3), Shims & Ring gear
bolts, pinion nut. 5 year warranty that includes
no gear noise.
$869.00 with core in.
(for 3.31 gear set add $100.00)
ALSO:
OUTRIGHT ( No Core Charge)
1980-82 Re-manufactured with New Gear Set
Outright with no core charge, Freight Free
$1295.00.
Available Ratios: 2:72 (call), 2:87, 3:07,3.31, 3.42,
3:54, 3:73, 3.92, 4.10, 4.27, 4.55 gear ratios
Returning core later call for current core charge.
REBUILD SERVICE:
All 1963-1979 and 1980-1982.
Same ratio rebuilds with core in: $589.00
Includes: Timken Bearings (6), CR Seals (3),
Eaton or Dana Posi Clutch Pack with Retainers,
Posi cross shaft, shims, crush sleeve where
applicable, Ring Gear Bolts, Pinion Nut.
5 Year warranty that includes no gear noise.
Rear Leaf Spring Hardware Kit
$49.95
Allows ride height adjustments as well as side-to-side leveling.
* 2 Grade 8 bolts with grade 8 Nyloc retaining nuts
* 4 Cushions
* 4 Cushion retainers
* 4 Plates for mounting the rear leaf spring
NEW Half-Shafts 1963-1982 includes U-Joints and Flange
1963 to 1979 21/2" or 3' $169.00 Each
1980-81 w/Manual Transmission $189.00
1980-81 w/Automatic Transmission $189.00
1882 All $167.00
Trailing Arms- New Bare
$190.00 each Bare Arm
Replace those worn rusted trailing arms, complete with bushings
installed. Bring back that new car feeling.
OEM Trailing Arm Alignment Shim Kit In Stainless Steel
STAINLESS STEEL
Your rear alignment could be effected by rust-out alignment shims.
Replace those rusted shims, improve handling, and reduce rear tire
wear. Kit for 2 arms includes alignment shims (4 different sizes), 2 Grade
5 mounting pivot bolts, cotter pins, and castle nuts, this kit does both
sides.
$59.00
Trailing Arm Mounting Pivot Bolts
$15.95/pair
Anchors bolt to frame, threw arm.
Caliper Mounting Bolts
$2.50/each
With lock nut and washer (mounts t-arm to spindle)
Spindle Flange Castellated Nut
$2.00/each
NEW Complete Trailing Arm Assembly w/Rear Wheel Bearing
$685.00 Each ( w/o rotor)
New, complete, and ready to bolt-on. This trailing arm is blueprinted
and professionally fitted using all new factory components, with new
heat treated and radius ground emergency brake shoes, and stainless
steel emergency brake hardware kit installed. Assemblies manufactured
with NEW:
* Limited Lifetime Warranty with unlimited mileage
* Anchor bolt
* Inner & outer seals
* Shim and spacer
* Spindle nut & washer
* Splash shield
* SS Emergency brake hardware
* T-arm bushing set
* T-arm studs & nuts
* Trailing arm
* Wheel studs
* Bearing support
* Caliper mounting bolts
* Caliper bracket
* Drive spindle
* Emergency brake shoes
* French locks
* Guide plate
* Inner dust shield
* Inner & outer bearing
* Inner & outer races
AVAILABLE WITH NEW ROTOR $745.00 Each Assembly
Drive Spindles (Rear axles)
$179.00
NEW manufactured 4340 HR ASQ/SBQ material, upset forge and
induction harden at factory. We obtain production runs of this premium
drive spindle, which enables this unit to be reasonably priced. Includes
new wheel studs. Made in the U.S.A.
NEW REAR WHEEL SPINDLE FLANGES
Spindle Flanges(1963-1979) $ 89.00
U-Joint Flange $ $65.00
Manual one piece flange 1980-1981 $91.00
All 1982
Auto one piece flange 1980-1981 $91.00
REMANFACTURED TRAILING ARM ASSEMBLIES
Remanufactured Trailing Arm Assembly 1965-1982
Remanufactured w/ Rear Wheel Bearing
$285.00 w/exchange* Lifetime Limited Warranty
Exchange units are blueprinted to factory specifications and completely
assembled with NEW:
* Anchor
* Cable guide
* Emergency brake components
* Guide plate
1963-1965 Drum Brake Models available.
Remanufactured Trailing Arm assemblies are also available with NEW
ROTOR $319.00 (with standard rotor)
Premium Rotor Add $25.00
REAR WHEEL BEARING ASSEMBLY
Remanufactured $219.00 w/exchange* Lifetime Limited Warranty
Units are remanufactured using your drive spindle, spindle (bearing)
support, and caliper mounting bracket. Assemblies are blueprinted to
meet or exceed GM specifications. Professionally fitted with NEW:
* Anchor bolt
* French locks
* Guide plate
* Inner dust shield
NEW Rear Wheel Bearing Assembly
$460.00 Each Lifetime Limited Warranty.
Blueprinted unit, is precision assembled using all NEW USA factory
components for years of trouble-free maintenance. Does not require an
exchange. These assemblies are manufactured with NEW:
* Anchor bolt
* Bearing support
* Caliper bracket
* Drive spindle
* French locks
* Guide plate
* Inner dust shield
NEW Rear Wheel Bearing Assembly w/New Rotor
$499.00 (Pictured LEFT)
Precision aligned and matched to the drive spindle.
Lifetime warranty.
HEAVY DUTY TRAILING ARMS
OFF-SET ARMS
$480.00 Pair
Improve bearing life. Will meet factory alignment specifications. Off-set
arms will center 10" wheels. Allows up to 2" over the standard tire size
and will match the same recommended factory alignment. Constructed
from 1/4" "C" channel, which will not allow any water retention inside
the arm. Coated with a special application of power coating. The units
come complete with polyurethane bushings.
NEW STRUT RODS
Reproduction of Original Style Strut Rods
V39282 1968-1974 (1.200" Outside Diameter Bushing)
VA7113 1975-1979 (1.390" Outside Diameter Bushing)
VA7114 1980-1982 (1.390" Outside Diameter Bushing)
Corvette Differentials, Corvette Parts 1963-1982
1963-1982 CORVETTE DIFFERENTIALS, POSITRACTIONS, TRAILING ARMS & PARTS
561-572-5323 Email: ORDERS@CORVETTEPARTSONLINE.NET
1963-79 and 1980-82 Differentials Available Outright with No Core Charge
PayPal for Secure Transactions
corvette 1963-1979 rear suspension and differential
half shafts with u-joints
view of shim assembly into frame
new rear forged axles
differential side axles (yokes) new
rebuilt spindle without arm
Posi gears
new stock strut rods with bushings
* Splash shield
* Strut, lever & pin
* Shim & spacer
* Wheel studs
* Limited Lifetime warranty
*Indicates items sold on an exchange basis, and cores must be received first for
exchange price. Items also sold outright (no core) at higher price. CP reserves the
right to refuse as exchange any damaged cores not suitable for safe rebuilding.
Prices subject to change without notice.
PayPal: fast, easy and safe without
sharing your info with the merchant. Link
your bank account, credit card and debit
card to your PayPal wallet and pay as
you choose.
* Inner dust shield
* Shim & spacer
* T-arm bushing set
* Splash shield
* Wheel studs
Heavy duty Offset Trailing arm
rebuilt spindle assembly with rotor
remanufactured trailing arm with rotor
another view of new trailing arm assembly
Trailing arm bolt kit mounts to frame
c3 differential and pinion flanges
rear axle flange 1963-1979
half shaft companion flange
raer axle flange 1980-1982
new barerear trailing arm 1965-1982
Go to 1963-1982
Ring & Pinions
1963-1979 differential
new Eaton positraction complete
completed 1963-1979 differential ready for shipment
Go to1963-1982 ring & pinion page
Go to 1963-1979 &
1980-1982 Differential
Side Axles
* Inner dust shield
* Shim & spacer
* T-arm bushing set
* Splash shield
* Wheel studs
Pictured Above, NEW 10-17
Gears for All EATON
CORVETTE Positractions
1965-1979 $239.00 Matched set
of 4 with Precision Heat Treat.
NEW DANA TRAC-LOK POSITRACTIONS 1980-1982
3-SERIES 2.73-3.73 $455.00
4-SERIES 3.90 & UP $455.00
See our selection of 3-series direct fit Ring &
Pinion Gear Sets.
AUBURN PRO POSITRACTIONS 1980-1982
3-SERIES 2.73-3.73 $496.00
4-SERIES 3.90 & UP $496.00
Rebuilt 1980-82
Differential
Forged Spindles after final machining.
Made in the U.S.A.
ratio)
1980-1982
no gear noise.
ALSO:
$1295.00.
REBUILD SERVICE:
$49.95
* 4 Cushions
1882 All $167.00
STAINLESS STEEL
sides.
$59.00
$15.95/pair
$2.50/each
$2.00/each
with NEW:
* Anchor bolt
* Shim and spacer
* Splash shield
* T-arm bushing set
* Trailing arm
* Wheel studs
* Bearing support
* Caliper bracket
* Drive spindle
* French locks
* Guide plate
* Inner dust shield
$179.00
All 1982
assembled with NEW:
* Anchor
* Cable guide
* Guide plate
* Anchor bolt
* French locks
* Guide plate
* Inner dust shield
* Anchor bolt
* Bearing support
* Caliper bracket
* Drive spindle
* French locks
* Guide plate
* Inner dust shield
Lifetime warranty.
OFF-SET ARMS
$480.00 Pair
NEW STRUT RODS
Posi gears
* Splash shield
* Shim & spacer
* Wheel studs
you choose.
* Inner dust shield
* Shim & spacer
* T-arm bushing set
* Splash shield
* Wheel studs
Go to 1963-1982
Ring & Pinions
Go to 1963-1979 &
Side Axles
* Inner dust shield
* Shim & spacer
* T-arm bushing set
* Splash shield
* Wheel studs
Gears for All EATON
Pinion Gear Sets.
Rebuilt 1980-82
Differential
Made in the U.S.A.
Old Nov 3, 2016 | 06:06 PM
calvette 11
the email address is orders@corvettepartsonline.net
Old Nov 3, 2016 | 06:13 PM
Sluefoot's Avatar
Sluefoot
Twould be nice if U wood go back & delete 1 of yer postings, as they are duplicates, extremely LONG at that!!
Old Nov 3, 2016 | 07:08 PM
sullyman56's Avatar
sullyman56
Callahan
I was able to bring up the website " corvettepartsonline.net". The site itself looks a little fishy, no contact info other than the email address. After clicking on the " interior parts " button I saw the phone number. I ran the phone number through Bing and wasn't too surprised to see a number of hits relative to complaints about poor customer service, failure to ship parts, shipping incorrect parts or not shipping anything and not answering phone calls or email inquiries. Doesn't look good and I hope you get your parts or find a way to get your money back.
Old Nov 4, 2016 | 12:20 PM
David in NC's Avatar
David in NC
does not look good, hopefully you paid by credit card
long list of lawsuits against them:
http://complaintwire.org/complaint/c...m-shuhi-carl-j
Old Nov 4, 2016 | 01:14 PM
hugie82's Avatar
hugie82
That really sucks and he wasn't even offering good prices.
Old Nov 4, 2016 | 02:09 PM
Alan 71's Avatar
Alan 71
Hi calv,
Not sure just what you mean by "I've been had"?
As David mentioned….did you happen to use a credit card? Sometimes they can be of help if things didn't well.
Good Luck!
Regards,
Alan
Old Nov 10, 2016 | 05:03 PM
tracdogg2's Avatar
tracdogg2
Old Nov 11, 2016 | 01:11 PM
calvette 11
Default rear end
Originally Posted by Alan 71
Hi calv,
Good Luck!
Regards,
Alan
I used a credit card check. They did not accept credit cards.
I got the parts on 11-8-16.There was only 1 axel in it. I got the second
one on 11-9-16.I will install it next week and see if it is good. I hope it is, it looks ok. I will let you know by next Thursday
Callahan
Old Nov 11, 2016 | 03:39 PM
Alan 71's Avatar
Alan 71
Hi C,
Well, that's sounding like this may turn out o.k. for you after all.
Wouldn't THAT be a good thing!
Regards,
Alan
Old Nov 21, 2016 | 11:27 AM
calvette 11
Default company
I got ripped off by fla. caliper about twenty years ago. I filed a report with the state of Fla.
I did not know it was the same person.
Thanks for the information
Old Aug 17, 2017 | 05:53 PM
BootzandI's Avatar
BootzandI
5th Gear
Default Stay away from this guy.
The owner of this business is Carl Shuhi. He lives at 124 SE 25th Ave Boynton Beach, Florida 33435. He and his girlfriend Lauri has ripped off literally thousands and thousands of people. I hope you have not sent him any money.
Callahan
To Help
