Q-jet help please
Old Nov 12, 2016 | 10:05 PM
COOLTED's Avatar
COOLTED
Default Q-jet help please
Ok, So my engine is out. When it was still running, it always smelled a little rich. Now I see the carb has been apart...no big thing, it's almost 40 years old. But I got to thinking that maybe someone tried to jet it or change the rods at one time in the past. Is there a way to find out what the stock jets and rods are supposed to be?
Old Nov 12, 2016 | 10:35 PM
7T1vette's Avatar
7T1vette
Yes.
Old Nov 13, 2016 | 08:48 AM
Alan 71's Avatar
Alan 71
Hi CT,
Your GM Chassis Service Manual will likely have the information you're looking for in the Carburetor area of Specification Section in rear of the manual.
In my 71 Manual it's pages 12,13, and 14.
Regards,
Alan
Old Nov 13, 2016 | 09:04 AM
'75's Avatar
'75
Post the number on your carb and Lars or some one will tell you.
Old Nov 13, 2016 | 10:11 AM
lvmyvt76's Avatar
lvmyvt76
GO Lars!!!! GO!
Old Nov 13, 2016 | 12:05 PM
lars's Avatar
lars
Give me the carb number and I'll give you the specs. Be aware that if the carb has been apart, I can tell you with complete certainty that other things have been changed and are out of whack other than jetting.
Lars
Old Nov 13, 2016 | 05:32 PM
COOLTED's Avatar
COOLTED
Lars
YES!!! awesome. Carb 17059216. there are some other numbers on it, 0319 and CMA. Carter built carb. Thanks!
Hopefully it hasn't been fooled around with, but after seeing that whoever took it off used silicone on the manifold to carb gasket, I started to worry.
Old Nov 13, 2016 | 05:55 PM
'75's Avatar
'75
I've got one just like it, same # in the basement if you end up needing one. From a 79, 72 main jet, 40 main rod, CH secondary rods.
Old Nov 14, 2016 | 07:33 AM
COOLTED's Avatar
COOLTED
Thanks for the offer, I will keep that in mind. hopefully I won't need it but we shall see.
Old Nov 14, 2016 | 12:02 PM
lars's Avatar
lars
Carb # 17059216 is an Impala, Camaro, Corvette and Nova 350 carb for an air conditioned car with auto trans. It should have #72 primary jets, #40K primary rods, and "CH" secondary rods. This is basically the same carb as the Vette/Camaro 17059203 carb, and it will run the same. A good float level setting for that carb on your car is .300".
Lars
Old Nov 14, 2016 | 12:16 PM
COOLTED's Avatar
COOLTED
Thanks guys. With any luck i will have my engine put back in soon, 2 weeks i'm guessing. I know the car will start with the carb the way it is, so after the cam is broke in it comes right back off for a rebuild. Thanks again for the help. Lars, your papers on tuning will be quite valuable. Thank You!
Old Nov 14, 2016 | 09:03 PM
'75's Avatar
'75
Lars, is the difference between the two is that the 17059216 is for auto trans and the 17059203 is for manual trans?
Old Nov 15, 2016 | 09:08 PM
lars's Avatar
lars
The differences between the 17059216 and the 17059203 are as follows:
17059216 was used on the A, B, F, Y & X model cars (Impala, Camaro, Corvette, Malibu, Nova, Monte Carlo and El Camino) with air conditioning, 350 or 305 and auto trans. 17059203 was only used on Vette and Camaro 350 with manual trans and no air conditioning. This means that the 17059216 had a solenoid & bracket assembly - the 17059203 did not. The 2 carbs also had different throttle bodies: The 17059216 used part number 17062717 with provision for the auto trans kickdown cable on the throttle lever, whereas the 17059203 used throttle body 17061363 which had no kickdown cable provision. The two carbs are otherwise completely identical and used the same parts and jetting components.
Lars
Old Nov 15, 2016 | 09:43 PM
'75's Avatar
'75
Thanks, that make sense, the I was pretty sure the 17059216 I have was from a 79 vette, L48 with auto and AC and you confirmed it.
To Q-jet help please
