Soft Top pics at high speed!!
Received 1,905 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Here's a couple of new pics from the recent 1/2 Mile event I took the Vette to. Managed 177 MPH...but it sure was a rough time on the 'ole soft top!!
JIM
JIM
The following 4 users liked this post by 427Hotrod:
Dementer sole survivor
Received 6,425 Likes
2016 C3 of Year Finalist
Could be worse
I am amazed the top stayed on at that speed
too would like to know what that red Vette was doing so close to you, do they not clear the course before another car starts ?
Congrats on the 177mph, it will soon be 200mph if you keep at it.
I've got extensions I install under the hood latches at the track to prop rear of hood open a little. At first I did it to clear a 1" spacer under the carb to get a few more HP....but I soon found the real benefit was to release some underhood air to keep the lift and hence the nose down. Since it helped at the dragstrip running 140+ MPH before the turbos...I figured it would definitely be a good plan for this event.
JIM
JIM
For me, I found the "roll start" to be OK...it let me get into 2nd gear early and then roll into the power. They had sprayed VHT around those pylons so you had a chance to get moving. On later runs I tried to get into it from a standing start and it was just a lot of wheelspin. Once they are spinning it's hard to get it back under control.
Next time I do this, I'll start from a standstill...and roll out and get into 2nd early and then apply power as hard as possible long before the "roll start" mark and get a lot more usable track to run on.
Heck of a fun way to send a sunny Saturday though!!
JIM
Jim,
It sounds like you made everything else for this car how about longer
guide pins like extenders for the hard top roof?
Then it could clear the roll cage/bar.
Just thinking out loud.
I saw the Jim Gardner L-88's were blue convertibles too but ran
hard tops on the track.
Marshal
Marshal
It was about 6500 RPM at 177 MPH. A little higher through the traps.
I'll want a longer shutdown area next time for my car.
I think it would be fun to join the "200" club! That's only about 7300 RPM!
I thought about adding extensions to the hold down mounts on the top...but decided against it at the time. The front latches hooked fine.
Certainly will have to do something else if I decide to "turn it up" and go faster.
JIM
JIM
Congrats of the great runs, having fun and not breaking!! That is testament to your design skills and preparation
The bubble top reminds me of when mine shredded on the highway one day at 80...scared the crap out of me!
BTW, the top inflates from air entering the cabin too, like thru the vents.
Bet you cant wait to try again with a few tweeks!
Thanks for my new back ground pic on my laptop....
That top pic is simply bad ***...That old top was wreaking havoc....
Congrats on hauling ***....Pretty crazy to think of an old, basically stock body/suspension car going that fast. Impressive to say the least.
Hi
Unbelievable that the softtop blows up like that.
I didn't drive 177 MPH yet and will never do with my 68, but had already over 200 kmh on it , never realized that the softop blows up .
Anyway, congrats on the 177 MPH .
I posted this link with a pic on the German Corvetteforum.
http://corvetteforum.de/thread.php?threadid=89885&sid=
Hope you don't mind . If you do, pls let me know and I remove it again.
Wbrgds. Günther
Wbrgds. Günther
