Bilstein Shocks
Old Nov 28, 2016 | 03:31 PM
Richard Daugird's Avatar
Richard Daugird
Default Bilstein Shocks
I know there has been a million threads on this, but this will be specific to my needs. I have the engine out of my '74 coupe for rebuilding. Plain Jane L-48 as far as I know, no Gymkhana or otherwise special suspension. I am going to do a full rebuild on the front suspension while it is out. I plan to use Wilcox's Polyurethane Made in USA kit. I will also lower the car by cutting the existing springs. I am doing this purely for cosmetics; the car, even with worn out suspension, handles better than I can drive, plus there is no where near me to really wind it out any way. From what I've read, Bilsteins are good for the money. I remember people recommend a mix between Sports and HDs, but I dis-remember which on the front(Sports?) and rear(HD?). I plan to keep the stock rear spring, and use longer bolts to lower. I also will be keeping the stock Rally wheels, with 255/60s(may jump up to 275/60 in the rear). Other question, will using these shocks on a lowered car, cause them to bottom out? I have had lowered trucks before(a few VERY low), and I know this can be an issue.
Old Nov 28, 2016 | 04:10 PM
DABall's Avatar
DABall
I run Bilsteins' HD's on all 4 corners on my '70 BB coupe. Stock suspension with 9 leaf rear steel spring. 255/60's all the way around. I couldn't be happier. The car never sees the track or any serious competitive driving.
Old Nov 28, 2016 | 04:30 PM
FKING1's Avatar
FKING1
Bilstein Sports all 4 with 550 cut front spring & 330 composite rear long rear bolts.
Track the car, no bottoming out.
Old Nov 28, 2016 | 04:38 PM
MelWff's Avatar
MelWff
since you are using the stock steel spring in the rear, I would do HD all around
you control arms front and trailing arms rear should have bump stops that hit before the shock bottoms out
Old Nov 28, 2016 | 04:39 PM
zwede's Avatar
zwede
HD's are softer than Sports so I'd stick with HD's for regular street driving.
Old Nov 28, 2016 | 04:51 PM
René K.'s Avatar
René K.
I have HDs iin combination with the stock springs front and rear. Comfortable but more precise ride. For street driving my preference!
Cheers...
René
Old Nov 28, 2016 | 05:42 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Think QA-1's. Just to be different.
Old Nov 28, 2016 | 06:03 PM
jb78L-82's Avatar
jb78L-82
I would use HD's all around for a base suspension car with a base rear steel spring.
I run Bilstein HD's in front with 550 springs cut 1/2 coil and Sports in the rear with my 360 composite. Originally a gymkhana suspended car from the factory...Car rides, steers, and handles MUCH better than the stock F-41 suspension ever did from the factory. Ride with 255/45/17 ZR ultra high performance tires is VERY comfortable on the street...firm but not harsh. It rides better than base suspension C3's I have been in by far...
Old Nov 28, 2016 | 06:18 PM
7t9l82's Avatar
7t9l82
I had bilstiens on my 88 lingenfelter trans am and they worked well for many years. on my 79 at the suggestion of VBP I installed QA1 shocks and I'm VERY pleased. they have a non adjustable version that is a bit less out of your pocket and are rebuild able should that become necessasary.
Old Nov 28, 2016 | 06:43 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
My QA1's are the non-adjustable type. Very pleased also.
Old Nov 28, 2016 | 08:18 PM
wendellp601's Avatar
wendellp601
Originally Posted by Richard Daugird
..... I plan to keep the stock rear spring, and use longer bolts to lower. I also will be keeping the stock Rally wheels, with 255/60s(may jump up to 275/60 in the rear).....
When I had 15" rims and 255/60 tires along with longer bolts to lower the rear, the sidewalls would flex and contact the end of the leaf spring. I upgraded to a 360lb composite spring that was a half inch shorter on each end. Also went with non-adjustable QA-1 shocks on the rear.
Old Nov 28, 2016 | 09:46 PM
LT1M21Vette's Avatar
LT1M21Vette
Also, HD are better with stock springs, and Sports are better with shorter springs.
Old Nov 28, 2016 | 10:46 PM
7T1vette's Avatar
7T1vette
With stock springs (leaf in back), HD's would be my choice [for your car]. If monoleaf in the rear, I'd choose Sports for the back.
Old Nov 29, 2016 | 12:12 AM
Richard Daugird
Thanks guys.
Old Nov 29, 2016 | 04:59 AM
Grahamred70's Avatar
Grahamred70
Thanks guys.
I fitted sport in the rear in preparation for my composite spring going in, no complaints with the steel spring since fitting the Bilsteins.
Will be fitting Sport in front as well when I get around to doing the front end later.
Graham
Old Nov 29, 2016 | 08:21 AM
Redhook98's Avatar
Redhook98
Same exact setup I have. Couldn't be happier. Feels like a new car.
Old Nov 29, 2016 | 03:05 PM
Cool bean's Avatar
Cool bean
+1 for Bilstien HDs up front for me too. I just completed the suspension on my 74 with what you're considering. 550 lb springs, cut about 1/4 coil (mostly so it would fit upper and lower pocket notches correctly....I chickened out on the half or full coil cut as has been described by jb78L82 and others. i can also cut it more once everything is settled) Urethane bushings, body mounts, Borgeson box, slotted cross shafts to get more caster. Unfortunately I can't comment on feel 'cause I haven't driven it yet; the engine just went in this week and have plumbing & wiring to do next.
On the rear suspension I did stock spring and shocks, but that because i started the restoration at the rear and hadn't researched suspension yet. Once I get the differential back from Traccdogg2 I'll swap the shocks out back to Bilstien sports, most likely.
To Bilstein Shocks
Old Nov 29, 2016 | 09:30 PM
mrvette's Avatar
mrvette
460 front 360 plastic rear, Billy Stein sports on all 4 corners....
ditch them stupid steel rear springs, your *** is setting on top of them, and the friction between the leaves make it a very rough ride....and too boot the sport shocks smoothed out a local undulating LONG bridge here locally.....springs are VBP and I think the shocks are too....they came along a lot later....
Old Nov 30, 2016 | 08:43 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Lol, mrvette. My QA-1's tamed my rear steel Gymkhana spring. Rides real nice so I'm not interested in forking out the cash for a plastic spring.
Old Nov 30, 2016 | 04:59 PM
7T1vette's Avatar
7T1vette
"Different strokes for different folks.."
Everyone has their 'favorite' approach. On the Forum we are just sharing our preferences with others. The OP gets to choose which way to go...
