68 Actuator relay locations
Old Dec 9, 2016 | 07:25 AM
Dave Vincec's Avatar
Dave Vincec
Default 68 Actuator relay locations
Howdy!
I'm trying to retrofit a vacuum system from scratch into a car that has had square lights fitted and the headlight door removed in the past...
Any chance someone could post a couple of photos showing where their relays are actually fitted?
Looking under the nose of my car - I can only see 2 bolt holes - which don't look right for the relay... and - is it ONE relay? some of the diagrams online seem to suggest one relay per headlight!
for the headlight actuator - there appears to be a spot on the wheel arch that looks about right - but it'd be good to confirm if i could!
Many thanks for your help
david
Old Dec 9, 2016 | 07:54 AM
Alan 71's Avatar
Alan 71
Hi david
I believe the 68 cars had a single relay that served both headlight actuators.
"Ts" in the hoses leaving the relay were used to allow one relay to control two actuators.
The relay was mounted to the underside of the headlight reinforcement bar in the space between the headlights.
Regards,
Alan
This is a photo of a 71 headlight vacuum set up. I post it ONLY to help you in the RELATIVE position of things.
Even with a single relay you'll still have a large red stripe and green stripe hose running to each actuator.
An example of the 'T' used. (This is a 69 car.)
Old Dec 9, 2016 | 11:09 AM
20mercury's Avatar
20mercury
Default Imho, ....
My 68 only has 1 headlight actuator mounted in the center of the nose header support bar.
My 68 wiper door has one actuator mounted on the passenger fender wheel on the inside the engine compartment.
Suggest you get an AIM (Assembly Instruction Manual) for the 68 Corvette, invaluable information. Check ebay or one of the Corvette vendors, should be about $25 or so.
Also, if you check some of the Corvette vendor catalogs they have great info on what and where things go. And I am thinking a lot of their catalog dwgs come straight out of the AIM.
Hope this helps
Old Dec 9, 2016 | 11:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 20mercury
...Suggest you get an AIM (Assembly Instruction Manual) for the 68...
Second that. The AIM could possibly help you a lot with replacing the stock head light system. The AIM shows all of it.
Old Dec 9, 2016 | 12:11 PM
Dave Vincec
Perfect, thanks guys... Alan - that engine bay is so clean I could eat my dinner off it!
Old Dec 9, 2016 | 03:06 PM
Alan 71's Avatar
Alan 71
Hi David,
Thanks!
It was fun to do and takes a bit of time to maintain!
Regards,
Alan
Old Dec 9, 2016 | 06:52 PM
DUB's Avatar
DUB
YES...the 1968 only used ONE headlight actuator relay.
It is mounted in the center of the support for your top hood surround ...basically in the same area that Alan shows in his photos. The fasteners show be a 10-24 machine screw if I am not mistaken.
The actuator relay for the wiper door is mounted to the backside of the right inner skirt.
DUB
Old Dec 9, 2016 | 11:24 PM
7T1vette's Avatar
7T1vette
If you ate dinner on Alan71's engine compartment, you would then have to wash it and dry it (just like your dinner dishes).
Old Dec 10, 2016 | 08:13 AM
Lobzila's Avatar
Lobzila
Are you dead set on vacuum? The reason I ask is that with the help of Richard454 on this site, I converted mine over to electric for less than 200.00 when it was all said and done. My engine produces very little vacuum at idle and you need at least 12" of vacuum to make the system work well. Mine had issues to begin with on the system. Works great now.
Old Dec 10, 2016 | 05:05 PM
Dave Vincec
I did consider going down the electric route when i realised i was having to start from scratch... and yes - it was originally the high prices cost of most of the electric conversion kits that put me off..
That said, I'm now thinking that i'd like to retain some originality where I can... and the quirks of the vacuum system are an original element!
In the case that I do have vacuum issues (it's a concern - see my other thread!) - I think prefer to spend some money to get a quiet-ish little vacuum pump to support the system rather than scrap it off. Perhaps i'm losing the plot/going nuts!
Old Dec 11, 2016 | 12:29 AM
7T1vette's Avatar
7T1vette
If the electric headlamp actuation method was better, Chevy would have stayed with the stuff used on the C2 cars. Interesting how they opted for vacuum AFTER the C2 'electric headlamp' venture.
Vacuum system is cheaper, more reliable, and easier/less costly to repair. Downside......most folks won't take a little time to learn how it works, so they're lost on how to work with it.
So.....let's throw money and time at the problem!!! Time to re-engineer what worked well for 30+ years........
Old Dec 13, 2016 | 08:37 AM
lvmyvt76's Avatar
lvmyvt76
To 68 Actuator relay locations
