Please Help ID This Part
Old Dec 12, 2016 | 05:34 PM
CrossedUp's Avatar
CrossedUp
Default Please Help ID This Part
Found it lying in the engine bay. Looks like some kind of ground strap that clips onto the edge of a piece of sheet metal somewhere? The car's a '69 L71 coupe that began its life with me as a basket case.
Thanks,
-Doug
Old Dec 12, 2016 | 05:39 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
On my 68 BB it's located under the drivers side frame rail to the stone guard.
It's a ground strap.
An AIM for 67 will show you exactly where it was originally mounted.
Marshal
marshal135's Avatar
marshal135
Marshal
Old Dec 12, 2016 | 05:50 PM
Alan 71's Avatar
Alan 71
Hi Doug,
Marshal is right!
AND, it's a nice find!!!!
I believe the intention was for the 'loop' end to be mounted to a small hole in the #1 body mount on the frame using a hex-head thread cutting screw and star washer, and the 'clip' was to be slid on to the forward edge of the birdcage rocker channel.
A bit of an unusual star washer was used originally… it has both internal and external 'teeth'.
Regards,
Alan
Old Dec 12, 2016 | 06:07 PM
CrossedUp's Avatar
CrossedUp
Originally Posted by Alan 71
Hi Doug,
Marshal is right!
Regards,
Alan
Ahah! I think I found it in the '69 AIM. Thanks guys.
Old Dec 12, 2016 | 06:16 PM
Alan 71's Avatar
Alan 71
Hi Doug,
Notice it's with the U69 option pages…. so only cars with radios got that ground strap!
Regards,
Alan
Old Dec 15, 2016 | 04:55 AM
marshal135's Avatar
marshal135
Nice Job Alan
Marshal
Old Dec 15, 2016 | 11:55 PM
suprspooky's Avatar
suprspooky
With Alan on the job, it's easy to get the correct info (usually with a pristine photo example). Yes that is a thank you/compliment Alan, post/in advance, as I've looked over many of your posts and expect to need more later.
Old Dec 16, 2016 | 12:19 AM
7T1vette's Avatar
7T1vette
Now, you should immediately put it on eBay, asking for $1000 for this "rare, factory-original piece of Corvette memorabilia". Wouldn't be surprised if some fool wanted to take you up on it.
Clean it up, put it back on your car; and you will be the only owner within 1000 miles to have that 'original' item on their car!
Old Dec 16, 2016 | 07:55 AM
lvmyvt76's Avatar
lvmyvt76
To Please Help ID This Part
