PS Pump recommendations - NOS?
Old Jan 4, 2017 | 09:45 AM
carbster09's Avatar
carbster09
Default PS Pump recommendations - NOS?
Hello
I have a '71 LS-5. I believe I am needing a PS Pump, any recommendations? NOS or US made would be best. I would consider a decent reman unit. I was thinking VBP maybe?
CC
Old Jan 4, 2017 | 12:24 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by carbster09
Hello
CC
My best luck was with GM-Rebuilt units. Direct from Dealership,
leak after 6-7 months.
other rebuilds from Cardone (Napa) went through 3 and they all leaked at different places and where noisy.
The GM units also leaked so GM Supplied me with rebuild kits to repair my self.
Is yours working but just leaks fluid, then first try a rebuild kit.
You do need a special puller to remove the pulley.
Old Jan 4, 2017 | 02:31 PM
zwede's Avatar
zwede
'71 is keyed, no puller needed.
Mine is a rebuild from Lonestar. I went through 3 of them before I got one that wasn't busted. It started leaking after a while so I took it apart and did a rebuild myself. They're easy to rebuild and the seal kit is less than $15. Found the reason it was leaking was Lonestar used the wrong o-ring in a couple of places (later pumps used thicker o-rings which they used on my early pump and that prevented the pump from seating fully in the housing).
After I rebuilt it, it has been fine.
Old Jan 8, 2017 | 07:27 AM
carbster09's Avatar
carbster09
Sounds like a lot of trouble for something so simple!
Thanks for the help
Old Jan 8, 2017 | 09:47 AM
forman's Avatar
forman
the rebuild is pretty straight forward go to you tube theres videos there that will guide you through it
Old Jan 8, 2017 | 10:50 AM
carriljc's Avatar
carriljc
Default Autozone a couple of years ago...
I got my replacement pump at Autozone about 4 years ago. I looked it over to ensure it looked the same, and transferred over a bolt/stud that was missing on the new one. Works great and no leaks.
FYI- I'm pretty sure I ruined the old pump myself by overtightening the PS hose and warping the body when I did not adequately secure the pump-reservoir body.... so be careful with that.
I did not feel terrible about it since it had been like 24 years since I added power steering and it had not given me any problems in that time.
Hello
CC
To PS Pump recommendations - NOS?
