New Console Installation Issues
Old Jan 6, 2017 | 12:25 AM
Corvettetodd's Avatar
Corvettetodd
Default New Console Installation Issues
I started out only planning on replacing my leaking Heater Core, and everyone know how that goes... The "while I am in there" list included new shift console, drivers side instrument cluster dash pad, quartz clock upgrade, etc..
I am trying to install the shifter plate on the console (automatic) and the shifter seals/sliders are contacting the a/c controller , causing it to bind ..(this happens when moving the shifter to park)
I already ended up having to replace the original a/c controller because the plastic shift shaft seals pushed one of the little pulley wheels off of the a/c controller and was lost..
This is on a 69 automatic with a/c..
Any Ideas on this?
Old Jan 6, 2017 | 08:32 AM
Alan 71's Avatar
Alan 71
Hi Ct,
Do you have the slide in this position when you're installing it?
Regards,
Alan
Old Jan 6, 2017 | 09:06 AM
Corvettetodd
I will have to check that... However, It was not an issue with the old shift console...
Originally Posted by Alan 71
Hi Ct,
Regards,
Alan
Old Jan 6, 2017 | 06:53 PM
DUB's Avatar
DUB
If what Alan posted does not work. A lot has to do with IF you have the A/C controller correctly caged in with the shift plate when it is being installed.
When both are correctly together. There should be no gap at the bottom area of the A/C controller in relation to the shift plate. THUS...this means it is UP high enough.
DUB
To New Console Installation Issues
