I have a 1980 L48 3 speed automatic and planning on putting in a 4 speed. Can anyone tell me which ones would be a direct fit without any modifications, Thanks
Gary
Gary
Muncie or Super T-10, I have pedals & linkage, if you or anyone else is interested send a PM
Gary
I have an 80 with the original T10 4 speed. If I had an automatic and was switching to a standard, I would be looking at an overdrive instead of the 4 speed.
If you're going to all that trouble, spend a few bucks and put in a five speed.
Automatic cars have a removable trans cross member; manual cars have a welded-in cross member. Since your cross mount is ONLY for automatic cars, I'm not sure that any manual trans will "bolt right in".
The best advice would be from someone who has done this. But, going from auto to manual would be easier, since you have a removable cross mount to start with.
Gary
Before I switched my 78 from auto to manual I test drove a few 4 speed cars. They shift like **** compared to modern cars. Now if you are a old school guy that likes to guide the shifter to the rails then you won't notice how bad a 4 speed shifter is.
My comparison was C3 vs C6 cars.
Then I tested cars with Tremec T56 6 speed transmissions (C6 corvettes)
Shifting up and down (2-3) (3-2) is a dream with the Tremec T56 Magnum.
My 78 feels like a C6 corvette shifter does.
After all the effort the T56 Magnum was well worth it.
Cost vs 4 speed is a different discussion. Wasn't cheap
only had one muncie that shifted SO good it stuck out in my mind
The rest even with all the tricks, shifters etc were so so.
once you go to a modern trans esp with a nice shifter youll never look back they are amazing. Seems like way too much when youre buying but it is truly a mod you will forget about the $ the very first time you drive, totally changes the car in a good way and those long runs on the hwy are now realistic.
With most on the hwy going 65-75 makes sense youll enjoy the car a lot more and not be the slow poke watching the tach and temp gauge
That is the truth. I switched my 75 from Auto to a Super T10 and was very surprised at how bad the shifting was. Still, a lot more fun than the 3 speed auto.
I will admit that the ST10 leaves a little to be desired. I went with it because it fit my skill level at the time and it has worked fine. But I would like to at some point replace it with a TKO600. Now that the pedals are there it wouldn't be too hard.
Jim
I have a 1980 L48 with factory 4 speed (BW Super T-10). It has the removable crossmember as well. The original 2 bolt main is gone in favor of a 4 bolt main 383. While it was out, i had the 4 speed rebuilt with new clutch. In the future, i will definately go with a 5 or 6 speed, but for now with all the $ sunk into the motor, the rebuild of the 4 speed was the way to go for me.
I am in the process of a auto to TKO600 5 speed conversion with SST's kit. I have not completed the install yet, but I will tell you their kit is VERY complete and appears very professional. Seems well worth the $$. In a year or so, I will know if the trans works as good as many have reported.
In fact, during the shipping process I had initially told them to include the wrong flywheel and AFTER it shipped, I called them in a panic to see if I could swap out the flywheel. They said no problem and without me asking, they called UPS had the package sent back to them and shipped me the correct flywheel all in the same time I would have had the original. I was astonished when the correct flywheel showed up. Highly recommended.
I can;t wait to do this swap too! I'm doing the TKO 600 with.64 OD hopefully by May this Spring. I considered 2004r's 700's etc but keep going back to wanting a stick.I'm doing the hydraulic clutch as well.Let us know how she runs when it's installed?
I was going to suggest that you consider installing an overdrive [manual] transmission. But, the 1980 C3 came with a 3:08 rear axle and at 70mph, your engine will only be turning about 2500rpm. An O/D tranny is unnecessary for that; in fact, the car would be 'lugging' at lower speeds unless you keep the trans out of high range.
A standard 4-speed box will be fine for you.
P.S. Shift quality is mostly a function of the shifter, links and bushings. Certainly, the gearbox has its shifting nuances, too; but in my experience, installing a good quality shifter with snug links and bushings will make most manual trannies shift quite well.
closer to ~ 2700 RPM. I like the 2000 RPM range, but if your engine has no torque that is a different problem, with my ZZ383 I am at 1700 RPM @ 70 MPH I have no problem cruising. If you want additional acceleration down shift to 5th now @ 2200 RPM @ 70 MPH More gears gives you more options, but you need $$$ to make that move.
And that is the problem by design. The T56 magnum shift quality vs any of the original 4-speed with any shifter installed is like night and day. Once you go forward you won't go back.
Actually, 2400-2500 rpm at 70 mph with stock diameter wheels. I have another car with 3.08 rear gear and it is dead-on with speedometer at highway speeds. It turns 2450 rpm at 70mph. My 3.36 C3 ('71) turns 2870 at 70mph.
A 3.08 rear gear and a .65 ratio high range O/D trans will turn about 1700 rpm at 70mph; and it will be lugging in high range at 40mph.
Finally, buy a better quality shifter to go with that 4-speed.
