how to wash down the engine???
Old Mar 29, 2017 | 08:53 AM
GTO1966's Avatar
GTO1966
Default how to wash down the engine???
guys , do I just cover the carb and distributer and spray the engine down with degreaser and rinse?
Old Mar 29, 2017 | 09:45 AM
blue by you's Avatar
blue by you
you can do that and cover the alt too make sure the engine is cold or you can do it by hand with a brush and rags
Old Mar 29, 2017 | 09:52 AM
ENCSDOUG's Avatar
ENCSDOUG
I would plastic wrap that the wife keeps in the cabinet to wrap food dishes. Easy to work with. I've even used that new stuff called press and seal and it works even better. I used it to spot paint areas in the engine bay to protect the parts from over spray.
Old Mar 29, 2017 | 10:02 AM
Big2Bird's Avatar
Big2Bird
Yes. I use full strength Simple Green. Works very well.
Old Mar 29, 2017 | 07:36 PM
kanvasman's Avatar
kanvasman
WD 40 works great if your wires or dizzy get wet Also. engines usually start right up after you wash them but the mistake is turning it right off Let it run for about 10 min and you'll be fine
Old Mar 29, 2017 | 09:44 PM
c3c4c6's Avatar
c3c4c6
I was told and always wash the engine while it is running. This way, if you wet something that should not be wet, you know it right away. It may just start to run a little rough, so you can stop what you are wetting.
Old Mar 29, 2017 | 10:05 PM
ignatz's Avatar
ignatz
I always went to one of those high-pressure, do-it-yourself car washes and soaped down and then rinsed and quickly restarted my motor. If your distributor is out in the open you might want to bag it. Never had a problem. On a hot engine the water steamed off real quick.
Old Mar 29, 2017 | 10:23 PM
Big2Bird's Avatar
Big2Bird
That "might" crack an exhaust manifold. "Just sayin...."
Old Mar 29, 2017 | 11:19 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I usually use a can of degreaser from Wally World at the car wash. Works great.
JIM
Old Mar 30, 2017 | 12:18 AM
ignatz's Avatar
ignatz
JIM
Wally World?
Old Mar 30, 2017 | 12:55 AM
7T1vette's Avatar
7T1vette
Pretty much like that...yeah.
To start, I would take the car to a quarter car wash that has the low pressure green tire/wheel degreaser setting. Bag the dizzy and carb (alt, too, if you want), and use that degreaser setting to cover the engine and compartment with that stuff. Let it set for about 5-10 minutes, then hose it off with Low Pressure Rinse. If that did pretty well but didn't get it all, do it again. If it didn't make a dent in the gunk on your engine, go buy some cans of GUNK. Then repeat the same process using the GUNK spray stuff.
This will get most of the grime off the engine and compartment walls. For the undercarriage, you will need to use the High Pressure spray to knock off the hard grease/grime/rocks/whatever. If really bad and you want to do a really nice redo of the undercarriage, you probably need to go to someone who can steam clean the underside first.
Old Mar 30, 2017 | 01:26 AM
Iceaxe's Avatar
Iceaxe
l'm thinking this is pretty much an old wives tale as I've washed literally hundreds of hot engines with never an issue. Also as an old off road racer I've drenched hundreds of hot engines while racing and never had an issue. This doesn't even begin to count the number of hot engines I've witnessed soaked by every method imaginable with no issues other than engine dying from soaked electronics with the problem solved after the electronics dryer out.
So my question has anyone ever personally experienced a cracked block, manifold, etc from washing a hot engine?
As an engineer I just don't think a properly running engine gets hot enough (250 degrees?) To cause issues with a steel part cracking.
Old Mar 30, 2017 | 06:00 AM
SH-60B's Avatar
SH-60B
I'm pretty sure exhaust manifolds get hotter than 250F, but no, I never harmed any motor, hot or cold from washing it.
Old Mar 30, 2017 | 09:47 AM
c3c4c6's Avatar
c3c4c6
I usually only wash them when they are cool, but with all of the rain/snow/puddles people ride through (I know, not with the plastic cars though) you never hear of manifolds cracking when they get wet.
Old Mar 30, 2017 | 09:53 AM
Alan 71's Avatar
Alan 71
Hi gto,
The oil/dirt on the engine and in the compartment has been protecting some of the parts from rust.
After cleaning the engine/compartment, the next day you may see that some rust has appeared that you didn't expect.
Regards,
Alan
Old Mar 30, 2017 | 04:05 PM
SwampeastMike's Avatar
SwampeastMike
Originally Posted by ignatz
Wally World?
A nickname for Walmart. Probably only well-known in the south and "flyover country".
Old Mar 30, 2017 | 04:23 PM
SwampeastMike
Personally, I wouldn't even think of using a pressure washer (my own or at any form of car wash) anywhere on my 'Vette! Not only were leaks into the cabin and/or birdcage and/or body mount locations nearly standard equipment but unlike newer cars extremely few of the electrical connectors outside the cabin are weatherproof.
To how to wash down the engine???
Old Mar 30, 2017 | 04:35 PM
7T1vette's Avatar
7T1vette
I think that it is relatively important to know WHERE to aim the pressure washer. If you don't know where to aim it, you shouldn't do it.
If you want to clean it...and it's grimy and greasy...you will need a pressure washer--or you will need a few weeks of 'elbow grease'.
Old Mar 30, 2017 | 05:40 PM
72 Project's Avatar
72 Project
Not cracked but DID warp an exhaust manifold enough that it leaked at the head mating surface on a 79 L82 back in the late 80s. Since then I do not spray cold water in great quantity on a hot exhaust manifold.
Jim
Old Mar 30, 2017 | 06:57 PM
BLUE1972's Avatar
BLUE1972
We call it that here on L.I. N Y .....
I use DAWN dishwashing detergent + you can pick the smell...
It will remove all the grease - so as was mentioned look out for rust...
Also any drips on the driveway - just go out when it rains and put a few drops on - rakes 2 - 3 rains and the spot is gone.. almost..
