Push start button
Old Apr 5, 2017 | 08:36 AM
hyprr1's Avatar
hyprr1
Default Push start button
Hey guys, wonder if you guys can help me locate the ignition wires under my steering column (starter, accessory, constant)
& what color the wires are?
I’ve installed a push button start & I’m having difficulty locating these three wires.
I was looking under the dash (steering column) last night and couldn’t really locate them.
Thank you,
Spiros
1980 Corvette
Old Apr 5, 2017 | 02:10 PM
Richard454's Avatar
Richard454
Look at the top of the column- see arrow.
That's your ignition switch- I've mapped it out for earlier C3- think 80 is different though.
Here's a 1980 wiring diagram-
http://www.keystonestatecorvetteclub...tte%201980.pdf
For pre-78 Vettes-
Old Aug 1, 2017 | 03:42 PM
Crafty12's Avatar
Crafty12
This thread is recent enough that I'm going to piggyback off it. How would I go about hooking up a push button setup like this?
Old Aug 1, 2017 | 06:22 PM
TimAT's Avatar
TimAT
You have it easy. Taped to the harness at the front of the console is a pair of 10ga purple wires- one with a white stripe. Feed 12v to one side of your switch and the other side of the switch to the purple/white stripe wire. Presto, instant start button. Note that this will crank the engine only and NOT provide power to the ignition. And this will also bypass your clutch safety switch.
Old Aug 1, 2017 | 06:49 PM
Patro46's Avatar
Patro46
I would never even consider doing this withou using a good relay and going through the clutch switch or the neutral safety switch. Ever.
Old Aug 2, 2017 | 01:12 AM
7T1vette's Avatar
7T1vette
Why???
Old Aug 2, 2017 | 03:19 AM
Patro46's Avatar
Patro46
Originally Posted by 7T1vette
Why???
Because the last thing you want is for someone to hit the starter button if your in gear, be it standard or auto.
I dig the pushbutton, like a Ferrari or some other exotic. But wire the safety switch(es) into the mix. Get a GOOD start button and it can do more than just spin a starter....
Old Aug 2, 2017 | 11:18 AM
Crafty12's Avatar
Crafty12
Yeah, I don't want to lose the safety systems. Can it be hooked up on the other side of the clutch safety switch?
Old Aug 2, 2017 | 11:28 AM
7T1vette's Avatar
7T1vette
Sorry... My "Why?" was in response to the original post.
Old Aug 2, 2017 | 12:45 PM
Richard454's Avatar
Richard454
Yes- it can. Hit the wire right at the column ignition switch.
BUT you also need to have the "push button" disengaged or electronically locked out after it's started- as the placement looks too easy to accidentally hit while driving down the road.
Richard
Old Aug 3, 2017 | 06:54 AM
The Punisher's Avatar
The Punisher
So is this used to bypass using a key in the column?
Old Aug 3, 2017 | 08:39 AM
Richard454's Avatar
Richard454
It can be...but you have to either remove or have a manual/custom steering column release- and then there is reverse lock out.
I'm using a keyless/remote system with transponders. I have to have the key fob to start the car.
And they are programmable- can walk away with the key fob and it'll lock the car.
I still have the clutch safety switch-have an electric power steering motor on the column so I just removed the steering column lock. Since I went w/ a 5 speed- just bypassed the reverse lock out. And then filled the ignition switch w/ a windshield wiper switch.
These are around $150-
Old Mar 2, 2023 | 11:42 PM
pochos80vette's Avatar
pochos80vette
3rd Gear
Default Push start
I want to do this on my 1980 i really don’t know how if someone could help or give like a good detail or photo how to do it i will appreciate it thanks
Old Mar 3, 2023 | 12:00 AM
pochos80vette
3rd Gear
Default How did u did the wire connections
how did u did this
Thank you,
Spiros
1980 Corvette
To Push start button
