Bouncing feeling
Old Apr 7, 2017 | 07:27 PM
newbie2vette's Avatar
newbie2vette
Default Bouncing feeling
I upgraded my 72 LT1 with full coil overs, for starting point I have the shocks adjusted at the halfway point, I went for a 20 miles test drive. The ride feels like I am bouncing on a ball; should I soften the ride or make it harder? Thank you.
Old Apr 8, 2017 | 12:56 AM
7T1vette's Avatar
7T1vette
HARDER. I'm surprised that ANY setting on shocks appropriate for that suspension would "bounce like a ball".
Old Apr 8, 2017 | 01:02 AM
The Punisher's Avatar
The Punisher
What brand of coilovers ? Spring weight?
Old Apr 8, 2017 | 01:04 AM
gkull's Avatar
gkull
What are your shocks I have QA1S dual adjustable shocks
Old Apr 8, 2017 | 08:39 PM
newbie2vette
I got the kits from Vansteel, the shocks are QA1. I did not see the spring weight identified on the kit specs.
Old Apr 8, 2017 | 08:53 PM
7T1vette's Avatar
7T1vette
The shocks (or one of them) could be defective. Do you get the 'bouncing' when turning in both directions?
Old Apr 8, 2017 | 10:24 PM
newbie2vette
It's mostly when I am going straight, I'm going to adjust the shocks to a higher setting and test drive to see if it helps.
Old Apr 9, 2017 | 01:23 AM
gkull's Avatar
gkull
I'm not sure about how to adjust the single adjustable qa1s. I have dual adjustable on front and rear
But I had to turn up the rebound. To control the bouncey ride when I first installed mine
To Bouncing feeling
