t top alignment
Old Apr 11, 2017 | 07:32 AM
blue by you's Avatar
blue by you
Default t top alignment
What is the best way to align the t tops on a 71 looks like my drivers side is not in all the way to the center
Old Apr 11, 2017 | 08:48 AM
Alan 71's Avatar
Alan 71
Hi bby,
There are 4 adjustment points for each roof panel.
The front outer corner alignment pin. It's moveable… two 12 point bolts.
The rear outer alignment wedge… 2 screws into the halo and the threaded wedge itself.
The pair of 'tongues' along the top's center edge… 2 bolts an shims.
I find that they all need to be loose to adjust the top panel successfully.
The interior trim panel should be removed so you can work from both outside and inside of the car.
Good Luck!
Regards,
Alan
Front outer pin, receiver, and lock.
Rear outer wedge and screws.
Rear outer lock.
Rear outer wedge receiver in roof panel.
Center forward.
Center rear.
Old Apr 11, 2017 | 10:00 AM
blue by you
Thanks alan, great pic as always
To t top alignment
