MSD-6AL Mounting
Old May 20, 2017 | 09:21 PM
A10pilot's Avatar
A10pilot
Default MSD-6AL Mounting
I'm upgrading my '69 L71 coupe with an MSD-6AL ignition. Have any of you done this? I'm trying to find a good place to mount the ignition box. Any ideas?
Old May 20, 2017 | 09:27 PM
Crimson Thunder's Avatar
Crimson Thunder
I put mine where the washer fluid bottle was installed.
Old May 20, 2017 | 09:38 PM
Corey_68's Avatar
Corey_68
When I was running a Big Block, I had mine behind the passenger dash. I wanted easy access and away from the heat and moisture under the hood.
Old May 20, 2017 | 10:45 PM
cagotzmann's Avatar
cagotzmann
Not sure if the 69 is similar. This is where I have my MSD Box on my 78
https://www.corvetteforum.com/forums...n-my-78-a.html
Old May 20, 2017 | 11:59 PM
theandies's Avatar
theandies
That's where mine is but a bit higher as I retained the windshield washer bottle. Been there 17 years with no problems.
Behind expansion tank. '71 Corvette
Old May 21, 2017 | 07:07 AM
A10pilot's Avatar
A10pilot
Thank you all for the quick response. I need to keep the washer fluid bottle to get an inspection sticker in Mass. Now I have some good ideas to start. The body is still off the car but will be mounted this week so I'll look at the ease of access after that.
Old May 21, 2017 | 11:14 PM
Kim72's Avatar
Kim72
Mounted mine in front of the radiator on a plate I made up. Been there for many years.
Old May 22, 2017 | 12:32 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I have mine in the wiper area. Old picture from when I was putting it together:
Old May 22, 2017 | 10:58 AM
540 vette's Avatar
540 vette
I installed mine on in my 72 on the opposite side right under the vacuum canister.
Old May 22, 2017 | 11:08 AM
zuendler's Avatar
zuendler
Have my 6AL2 hidden behind the expansion tank.
Old May 22, 2017 | 11:14 AM
DABall's Avatar
DABall
I installed mine inside the car under the passenger side below the dash. Easy access and keeps it away from the heat and the elements. Engine bay looks stock.
Old May 22, 2017 | 11:37 AM
A10pilot's Avatar
A10pilot
Great stuff guys! I appreciate all the help.
Old May 22, 2017 | 09:10 PM
drwet's Avatar
drwet
In my '79:
To MSD-6AL Mounting
