Radiator fitment
Old May 26, 2017 | 04:24 PM
lsintampa's Avatar
lsintampa
Default Radiator fitment
So I replaced the radiator support today.....
Here's my issue... with all new seals on the support and the shroud, etc. I can't seem to get the radiator to "seat" well on the bottom supports.
The right side seems to be sitting down but the left side bottom radiator seems to be about half an inch up from the lower support.
I've been trying to persuade it down but no such luck. I'm beginning to suspect that the support is a bit "off".
Stupid me, didn't think to fit the radiator and support while they were out of the car. I hate the thought of taking them back out, but unless there is some other trick I can try, that looks like where I'm heading.
Thanks for any suggestions.
Len
Old May 26, 2017 | 04:42 PM
Alan 71's Avatar
Alan 71
Hi Len,
Is the core support designed to accept the radiator you're installing?
Has it seated properly in the past?
Regards,
Alan
Old May 26, 2017 | 05:05 PM
lsintampa's Avatar
lsintampa
Originally Posted by Alan 71
Hi Len,
Is the cote support designed to accept the radiator you're installing?
Regards,
Alan
Yes, it is the radiator that was in the car.... while I had it out, I took it in to rad shop for good clean / testing....
I think the issue I'm having is the new foam seal that rides the bottom lip of the support. The bottom of the radiator is flush up to that foam (new) and I can't compress it enough for the radiator to seat all the way down.
I can pull the foam out and then I think the thing will sit down.
OR
Maybe just let it recess over time as the foam compresses.
IDK - this is my first american car rebuild (all Euro's in the past) and I have to say that so far nothing has been easy.
Thanks,
Len
Old May 26, 2017 | 05:28 PM
Alan 71's Avatar
Alan 71
Hi Len,
Is it possible that the seal could go/get worked into place after the radiator is seated in the supports?
Regards,
Alan
Old May 26, 2017 | 05:51 PM
DUB's Avatar
DUB
Do you still have the old radiator support...and if you do..are the lower supports still intact???
DUB
Old May 26, 2017 | 05:57 PM
lsintampa's Avatar
lsintampa
DUB
Yes still have it and the lower supports are still there... it is rusted along the bottom and sides.
To Radiator fitment
