71 Idle stop solenoid
Old Jul 2, 2017 | 02:36 PM
Jim71Vette's Avatar
Jim71Vette
Default 71 Idle stop solenoid
While I have off the carb.... is there a way to test it?
Old Jul 2, 2017 | 04:23 PM
Alan 71's Avatar
Alan 71
Hi J71,
The 71 engines have a emissions control solenoid mounted on the front left of the carburetor.
The solenoid has an electric/mechanical function.
When 12 volts is applied to the 'prongs' on the plunger the plunger should 'fire' (extend out the opposite end of the solenoid.
and….
The supply port for vacuum to the distributor should open.
Regards,
Alan
Old Jul 2, 2017 | 05:22 PM
Jim71Vette's Avatar
Jim71Vette
Thanks Alan and the pictures are great.
I probably should start a new thread for this question.... but were did you source your FP to carb hard line?
Back when I was collecting parts I knew I would need, I bought 1 from CC. When I recently installed it didn't fit correctly, it went over the valve cover.
Old Jul 3, 2017 | 07:18 AM
Alan 71's Avatar
Alan 71
Hi Jim,
There seem to be 2 variations of the pump to carburetor hard line.
One running above the heater hose and one running below it.
I 'believe' the one running below the hose is typical of 71 production.
I'm not sure at this point who is selling which.
Regards,
Alan
I guess the options are ZIP, Dr. Rebuild, CC, and Paragon.
Old Jul 3, 2017 | 09:00 AM
7T1vette's Avatar
7T1vette
That solenoid may take some significant current to fire Probably best to power it with an auto battery. If you measure the resistance (ohms) of the solenoid, you can easily determine the current it would draw with a 12vdc supply.
Old Jul 3, 2017 | 09:37 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Alligator clips and a 9V battery will work to test the solenoid.
To 71 Idle stop solenoid
