Electric brakes
Old Jul 12, 2017 | 09:18 PM
Big2Bird's Avatar
Big2Bird
Default Electric brakes
Okay, I saw a Fantomworks where they installed "electric brakes." I have also now started seeing it in magazines. What's the scoop? Just curious is all. ANybody install/use these things?
Old Jul 12, 2017 | 09:35 PM
68blvert's Avatar
68blvert
I haven't seen any used in the primary braking system but the oem's are starting to use them in the park brake systems. Ford, Volvo, Volkswagen, Subaru, to name a few, are the ones I've worked on. Rear calipers with an integrated e-brake actuator in the caliper. You push a button on the dash to engage and disengage the park brake. No more foot pedal or handle. These calipers are $$$ to replace. AND you have to have a scan tool capable of communicating with the chassis module to tell it to retract the piston so you can change the brakes.
Old Jul 12, 2017 | 09:46 PM
terry82's Avatar
terry82
I seen that. the car already had wilwood brake calibers.i also was surprised when they swapped out the edlebrock carb for a holly .I would have thought they could have rejetted if needed.The car was for a guy in a wheel chair.Maybe they meant electric brake hand controls.
Old Jul 12, 2017 | 10:23 PM
Big2Bird's Avatar
Big2Bird
http://www.speedwaymotors.com/Electr...SABEgIoq_D_BwE
Old Jul 12, 2017 | 10:39 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Interesting, electric brake booster...
Old Jul 12, 2017 | 11:42 PM
sparky77's Avatar
sparky77
The CFM on the carb was to big thats why they changed it ,The electric booster is taking the place of the vacuum booster and remotely mounted to give you more room under the hood.
Old Jul 13, 2017 | 06:35 AM
Richard454's Avatar
Richard454
I have a completely electric PARKING brake...
e stopp
Old Jul 13, 2017 | 09:14 AM
gungatim's Avatar
gungatim
never thought about it before, but my trailers have electric brakes. I guess no reason you couldn't use them on a car, but why bother?
Old Jul 13, 2017 | 09:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
richard how do you like it
only experience ihave is on our hyundai rental hate it. Way too sensitive, steering too.
Old Jul 13, 2017 | 09:55 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
What's the back up brake system if there's an electrical failure?
Old Jul 13, 2017 | 10:50 AM
Kacyc3's Avatar
Kacyc3
airbags
Old Jul 13, 2017 | 11:17 AM
71 Vert LS1's Avatar
71 Vert LS1
Looked like a electric vacuum pump?
Old Jul 13, 2017 | 11:40 AM
TimAT's Avatar
TimAT
Kind of a different deal- trailer brakes are usually electro-magnetic. The brake controller senses you've stepped on the brakes thru the stop light switch and sends voltage to the electromagnets at the wheels. Old ones even tapped into the brake hydraulic system at the master cylinder and sensed that way. This thing is a power booster that's electric.
Old Jul 13, 2017 | 12:25 PM
Big2Bird's Avatar
Big2Bird
I would "assume" it is like any other power brakes. It would just become manual.
Old Jul 13, 2017 | 03:39 PM
kansas123's Avatar
kansas123
I've never thought about it before, my Hyundai Sonata Hybrid has electric power brakes and steering. Maybe I'll get out the encyclopedia that came with the car and look into it....
Old Jul 13, 2017 | 08:56 PM
Big2Bird's Avatar
Big2Bird
Now that you mention it, the wife has a Volt, and I have all the manuals.
Old Jul 14, 2017 | 02:31 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Some newer airplanes have done away with engine driven hydraulic pumps and all the plumbing associated with distributing that pressurized fluid to the components that need it throughout the aircraft. Now they just put combination electric pumps/hydraulic actuators right where they are needed.
Paul
To Electric brakes
Old Jul 14, 2017 | 02:34 AM
JayRay's Avatar
JayRay
Can they be hacked?
Old Jul 14, 2017 | 01:01 PM
ddawson's Avatar
ddawson
That's pretty cool. Once more are on the market I'd look into it as well.
I'd want to see some brand name stuff for warranty and support purposes, because that's a lot of coin.
Old Jul 14, 2017 | 05:01 PM
Richard Daugird's Avatar
Richard Daugird
More **** to go wrong and cost incredible amounts to fix. So when the brakes need replacing, you **** can the car and buy a new one. Planned obsolescence.
