Fiber optics question
Old Jul 13, 2017 | 09:03 PM
Rev Ron's Avatar
Rev Ron
Default Fiber optics question
I'm restoring a 70 with fiber optics. On the front end, two plugs go to the turn signal light... and that is all I see up front... but there are 6 fiber optic light monitors on the console... what do the other 4 monitor?
Old Jul 13, 2017 | 09:38 PM
Tiger Joe's Avatar
Tiger Joe
Headlights
Old Jul 13, 2017 | 11:18 PM
TimAT's Avatar
TimAT
From the front, there are 6 fiber optic lines- all 4 headlights and the 2 park lights. The headlight fibers go into the center of the plug for the bulbs and have a sponge seal that fits over the tit on the back of the bulb. My sponge seals are long gone, and me being too cheap to buy new, I used a short bit of vacuum hose.
Old Jul 14, 2017 | 03:13 AM
theandies's Avatar
theandies
Didn't know that.
I don't have those either but my FO work fine. I even did the relay upgrade and modified my new ceramic plugs with the FO ends. Used some high temp red RTV to hold them in place. Worked fantastic.
Old Jul 14, 2017 | 05:38 AM
Rev Ron's Avatar
Rev Ron
I had a new wiring harness put into the front. I see the optics for the turn signals. Are the optics for the headlights included in the bundles with the other wires that provide power for the headlights?
Old Jul 14, 2017 | 07:21 AM
Alan 71's Avatar
Alan 71
Hi rr,
Here you can see the fiber optics cable in the center of the headlight connector… typical for all 4.
Regards,
Alan
There are also small black plastic tubes that are part of the connection that ensure all the light from the lamp is gathered onto the cable.
AIM UPC12, Sheet A4
Old Jul 14, 2017 | 10:38 AM
69L46vert's Avatar
69L46vert
If the harness came with parking light FO then it seems certain it would have come with headlamp FO.
Keep in mind too that not all headlamp bulbs will work with FO. Many of the new halogen bulbs don't allow any light through the backside of the bulb. Some even have a rubber boot that blocks all light rendering the FO inoperable.
Old Oct 18, 2017 | 03:41 PM
TSKieffer's Avatar
TSKieffer
5th Gear
Default Fiber Optic Repair and Replacement Parts
I found an excellent source of fiber optic repair and replacement parts using the following link:
http://www.zip-corvette.com/68-82-c3...year/1969.html
Thanks for your posts with the illustrations...
Old Oct 20, 2017 | 12:45 PM
OldCarBum's Avatar
OldCarBum
This may be a dumb question but I'll ask anyway, What years C3's used fiber optics as part of the lighting?
Old Oct 20, 2017 | 04:22 PM
Alan 71's Avatar
Alan 71
Hi OCB,
The fiber optics system was standard equipment on 68-71 cars.
Regards,
Alan
To Fiber optics question
