Overheating during break in? Electric fan not strong enough?
When I finished the break-in for my new engine (91 TBI 350 block, Aluminum 64cc heads, .490 lift Comp XE274 Cam, Springs, roller-tip rockers, headers, etc), she started to spit steam out of the vent hose on the reservoir despite the new electric fan running at full-speed.
The outside temperature was 95 degrees with no humidity (Vegas dry weather). So my Radiator was working perfectly before and seems to be in great condition (PO replaced it with a $600 Rad about 13 years ago and drove only 2,000 miles).
My break-in process was to rev between 2k-2.5k for 30 mins
I'm thinking maybe I need either a shroud or a stronger fan (fans?). What do you guys think? (I believe my current one is rated at 2,000 CFM. Flex-A-Lite Syclone)
(Temporary wiring was just to have it working for break in)
Edit: Pulleys and belts were both installed during break-in. Only removed them a couple hours before the pictures were taken
Received 3,043 Likes
St. Jude Donor '05
Is your thermostat opening all the way, timing retarded by chance?
If its getting that hot just running stationary not sure a shroud is the answer just yet
What kind of effect does the fan have on the system when it does come on? Some aftermarkets are ok, others are less than good.
Received 2,878 Likes
Hi Sd,
I'm a pretty poor mechanic… but in your photo, what's driving the water pump?
Regards,
Alan
Regards,
Alan
St. Jude Donor '05
good eye missed that
So I'll check the thermostat. That's one thing I didn't replace during the engine build. Timing shouldn't be retarded, I got it pretty spot on 0. The fan definitely cools, but I don't have a working temp gauge at the moment so I can't tell you exactly how much it cools
St. Jude Donor '05
most auto parts store will have a cheap water temp gauge you can stick in your head just for the sake of monitoring it takes minutes to put in.
May as well get a new stat , drill a couple 1/8 in holes around the outside ring to help burp any air out
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
very common for things to get toasty while sitting still and breaking in a cam. No airflow and a lot of heat built as things get acquainted with each other.
I remove the T-stat all together. I place a box fan somewhere to help remove heat from engine area. I also keep a water hose handy to mist the radiator while it's running. I set the timing higher than normal to keep it cool. And richen the idle screws to let some fuel flow.
JIM
JIM
Actually my bad. Had a friend helping with the timing while I ran her. Says he set it right about 10 degrees before.
It is possible I was running a bit lean as well, but I'm gonna remove the thermostat before I do anything else. I'll do a more thorough tune according to Lars' documents and see if that helps
JIM
your missing half your radiator, you must use a shroud to direct air flow around all of your radiator, without it your missing hugh amount of cooling capacity.
you must use a shroud.
Just as a side note. My radiator guy loves those ty wraps thru the core.
They vibrate, have teeth, and over time file thru tubes.
Consider a shroud mounted NOT to the core.
St. Jude Donor '05
dont time it by ear, I did that once out of laziness just to break in a cam, was way off. So retarded I ruined a brand new set of jet coated headers and fried my exh gaskets;had a few exh springs break quickly wondering if the valves got too hot headers were literally glowing
some guys will use some junk exh manifolds (make sure they arent lean/rich) then install the headers
I did the same thing cuisinart did, pic is below.
more things to check: make sure radiator and engine is full of antifreeze with no air pockets. Timing is not advanced enough at 10*.
here's my headers when timing was retarded during breakin. Ouch.
Glowing headers due to retarded timing. Ouch.
I said set it at 16* at idle, and ADVANCE it by ear while running. IE, way up there. At 2000rpm, you could set it at 40* and it would be fine.
I've helped friends do this. They start it, the manifolds get hot, and I grab it and twist it advanced till it cools down. If the rpm backs down, I retard it to the sweet spot.
I then set it up with a timing light after the break in. 36* at 3000RPM, vacuum plugged.
St. Jude Donor '05
I hear what youre saying we all used to do that I just screwed up royally it looked like that posters pic so much for the new engine smell it was not pretty. lol
how many of us got lucky back in the day with the "advance it til the starter just starts to kick back then go backwards a hair" and really believe it.
