A/C Restoration Question
Old Jul 26, 2017 | 08:20 PM
ONeill202's Avatar
ONeill202
Default A/C Restoration Question
I have a 70 with factory air that has never worked since I've owned it. I've been debating on whether I should try and fix it or replace it with a Vintage Air unit. I hear Vintage Air units are pretty good and not too difficult to install.
I have a feeling my compressor is shot and every other element is going to needs replacing, but I'm not an A/C person so I'm not sure.
Since the vehicle is mostly original and it is a matching number car I'd keep the original unit for decoration if it's not repairable
Anyway, please let me know your thoughts on how I should proceed.
Thanks,
Al
Old Jul 26, 2017 | 10:32 PM
7T1vette's Avatar
7T1vette
If you have an a/c car, swapping to R-134a with a conversion kit is probably a better choice, unless you suspect a mechanical failure that put metallic debris in the system. The conversion kit provides a new Sanden compressor, brackets, main hoses and a replacement for the POA valve. Much less expensive than the Vintage Air system and much easier to install, since it re-uses the bulk of the original system (evaporator, condenser, system controls and ducting.
Old Jul 27, 2017 | 10:37 AM
ONeill202's Avatar
ONeill202
Where can I get a conversion kit?
Old Jul 27, 2017 | 10:57 AM
BlackC3vette's Avatar
BlackC3vette
If you have a good AC/Radiator shop near you, you could bring it in to have them check the system. It could be something simple.
Original Air Group is one conversion kit. There are others out there. I just ordered a new original style compressor for my 80, I actually ordered it thru the Rock, but Amazon had them also. It was the cheapest, fastest way to get my AC back in the heat of the Summer. The shop I deal with told me to order one online, bolt it up and bring it back for them to recharge the system.
Old Jul 27, 2017 | 02:32 PM
domenic tallarita's Avatar
domenic tallarita
Al,
Don't give up on your A6 compressor. They are bullet proof if buba didn't pound a new clutch hub on or if it was dropped on the clutch which could bend the shaft.
I would suggest pressure testing the system rather than testing it pulling a vacuum. If you do pull a vacuum and pass and you do not see visible oil at the connections and clutch, you may be OK.
I have not seen one make metal. I do see 95% of them with rust inside because they are about the only part of the system that can rust. That doesn't stop them from doing their job. The mineral oil they use doesn't seem to prevent rust. There are newer oils that say they prevent corrosion.
You can always put a small charge in it and use a sniffer. I used propane.
Dom
Old Jul 27, 2017 | 02:34 PM
ONeill202's Avatar
ONeill202
I could be mistaken but somehow I remember these A/C units not being very good, am I wrong about that?
Old Jul 27, 2017 | 03:09 PM
BlackC3vette
I am not going to say they were great. The AC in my 69 Nova, 73 & 72 camaros worked well with that style compressor. My 80 has a different style than your 70. I would try to find the problem first before changing out the whole system.
Old Jul 27, 2017 | 04:23 PM
7T1vette's Avatar
7T1vette
I bought my conversion kit from Classic Auto Air. Very pleased with kit quality; all needed items were in the kit.
I do agree that you should have your existing system checked out first. I know of folks who had a defunct system for years...only to find out that the pressure switch went bad on it. Replaced the defective switch, vacuum/charge system and it worked fine!
Have your system checked FIRST. Once you know the fault[s] in the system, you can decide the best course of action: repair your existing system; go with a conversion kit; replace the entire system; leave it as "non-functional".
Old Jul 27, 2017 | 08:23 PM
ONeill202's Avatar
ONeill202
I'm also missing the duct that goes under or above the steering column if anyone has one they'd like to sell.
Old Jul 28, 2017 | 10:29 AM
hugie82's Avatar
hugie82
If the system is still fully intact, I would try putting a vacuum on the system and see if it can hold a vac. But a system sitting that long, it might be more cost effective to go vintage air with better results.
Old Jul 28, 2017 | 12:36 PM
Wee's Avatar
Wee
eBay or one of the forum suppliers.....Expect to pay around $100.
Brian
Old Jul 28, 2017 | 02:08 PM
ONeill202's Avatar
ONeill202
Here's what happened today.
I had all the controls set to off and the compressor connector disconnected. I started the engine and connected the compressor. The clutch engaged but the compressor pully didn't move. I'm assuming the compressor which I was told was new when I bought the car is frozen.
Old Jul 28, 2017 | 05:46 PM
mortgageguy's Avatar
mortgageguy
If it was locked up, wouldn't the belt be screaming?
Old Jul 28, 2017 | 05:57 PM
ONeill202's Avatar
ONeill202
Yes sir, it was screaming.
Old Jul 28, 2017 | 09:05 PM
7T1vette's Avatar
7T1vette
Anytime you purchase a car with the A/C "not working", it is NEVER a simple task to make it operational. If it were, the seller would have already fixed it so that the selling price could be higher.
Probably a 'shot' compressor. You could run it by an A/C shop for a better opinion, but tell them that is ALL you want and know what the 'inspection' charge is before they touch it. If the compressor is bad, the next thing to do is remove the compressor and see if there is any trash (metallic debris) in the refrigerant lines hooked up to it. If not, you have a good candidate for a conversion kit; if you have debris in the system, it would probably be best to install the complete Vintage Air (or similar) system.
P.S. It is still "possible" that the bearing in the electric clutch (on the front of the compressor) is all that is bad. If that car had sat for many years, it was likely frozen and if energized, it could have just locked up. If that is the case, just changing the clutch may actually solve your problem. Again, the A/C shop would be able to tell if that is the case. If it is, just pay that shop to put on a new clutch, test compressor function (and maybe replace that front seal), then vacuum it down, charge it, and try it out. IT COULD HAPPEN!!!
Old Jul 28, 2017 | 10:31 PM
domenic tallarita
Good advice, but if the pulley stops the belt will burn. The bearing is in the pulley and the electro magnet pulls the clutch (very front) hub to the spinning pulley to engage the inner works of the compressor. Any time the engine is running the pulley will turn. The clutch magnet will pull the front hub to the pulley and turn the inner works of the compressor.
Never found any metal in a A6 compressor, so rest easy there. Hope this helps.
Dom
Old Jul 29, 2017 | 09:30 AM
ONeill202's Avatar
ONeill202
Should I pull the compressor off the engine or can I work on replacing the bearing while on the engine? Also, why is the clutch engaging when I have all the switch controls set to off?
To A/C Restoration Question
Old Jul 29, 2017 | 10:20 AM
BlackC3vette
If you disconnect the electrical connector from the compressor, does the clutch disengage? If so, the problem will be in your controls.
Old Jul 29, 2017 | 05:39 PM
ONeill202's Avatar
ONeill202
I think you're right.
On another note, I have my heater door closed but it still seems like heat is making its way in to the cabin. Have you by-passed your heater core? If so how did you do it? I'm trying to get the cabin a bit cooler considering the 100 degree weather we are having here....
Old Jul 29, 2017 | 06:07 PM
domenic tallarita
I think that the question that BLACK C3 asked is something that needs to be answered and it's a simple pull on the connector that is on the compressor.
If it does turn, (the front hub with the rubber), with the connector un plugged and engine running, then your clutch is fused together.
As I said in my other post, If the pulley won't turn, the belt will burn because the pulley ALWAYS turns and the belt will be slipping across the frozen pulley making one he!! of a noise. No such thing as a clutch bearing on a A6.
Dom
