Wrong motor mounts
Old Jul 31, 2017 | 11:22 AM
forman's Avatar
forman
Default Wrong motor mounts
I recently got my motor running real good after some tweeting but noticed when I put my motor mounts in there's way to much play in them the motor shakes too much and I'm not to happy with the mounts .. When I went to the auto parts store the guy said they are the right ones .. And me like a dummy already threw mine out and had nothing to compare too .. I have a 1970 with the 454 it's a march car and I recently read a article that they changed the mounts after a certain month from the 69 to 70 in cars after June of 70 here's the pictures and you tell me
Old Jul 31, 2017 | 11:50 AM
Alan 71's Avatar
Alan 71
Hi f,
My understanding is that 68-69 cars didn't have the 'safety mount' but 70-72 cars did.
Here's an example of a safety type mount.
Regards,
Alan
Old Jul 31, 2017 | 12:50 PM
Dynra Rockets's Avatar
Dynra Rockets
I went through this same research myself when looking at motor mount options to buy
IIRC, the stand width is 2 3/8 for non-safety lock mounts and 2 5/8 for 1970+ safety mount (BB) style.
Was your car originally a small block car? If so then just use small block mounts so they fit the stand (or use washers to take up the space).
Old Jul 31, 2017 | 02:10 PM
forman's Avatar
forman
I guess the question I'm asking is if the 69-70 mounts are the same .. That's what I need to know but I do appreciate the photo
Old Jul 31, 2017 | 02:13 PM
Dynra Rockets
IIRC, 68-69 BB motor mounts were the same as small block so did not have the safety. starting in 1970 the BB motor mounts added the safety so they are wider.
from the pic of your stand either you car was originally a small block (2 3/8) or you car was before the cutover to the newer BB safety style (2 5/8).
You have two choices 1) source small block mounts 2) use washers as spacer for the mounts you have.
Old Jul 31, 2017 | 02:23 PM
Alan 71's Avatar
Alan 71
Hi,
There are not big block and small block engine mounts.
There were not big block and small block frames.
The same mount was used for bb and sb engines in 68-69 production and then changed and used for 70-72 production.
There IS a difference in the mount used in those 2 periods.
Regards,
Alan
If you car has a 70 frame it needs 70-72 motor motor mounts.
forman's Avatar
forman
I would rather just buy the right mounts ... The car is a real 454 car so if I got the 69 big block mounts do you think they would work I really don't want to put washers in there
Old Jul 31, 2017 | 02:37 PM
Dynra Rockets
Grab a tape measure and measure the width of the stand and compare to mounts at your local auto parts store. From your pic it looks to be the 2 3/8 width style.
Old Jul 31, 2017 | 02:46 PM
Dynra Rockets
Originally Posted by Alan 71
Hi,
Regards,
Alan
http://static.speedwaymotors.com/RS/...R_1ce771f7.jpg
http://www.pozziracing.com/Media/camaro_eng_mounts.jpg
Old Jul 31, 2017 | 03:19 PM
Haggisbash's Avatar
Haggisbash
I recently had to change the mounts in my '70 small block (one mount had been too loose at some stage and over time the bolt oval-led the hole in the stand, if you leave yours the way it is you could have the same issue). The replacement locking mounts seem to be all the same to me except for the narrower stands the mount has spacers welded in it.
You would achieve the same thing by adding washers to your existing mounts but if they are the non locking type I would suggest changing the LH one at least to a locking one. JMPO
Old Jul 31, 2017 | 03:25 PM
Alan 71's Avatar
Alan 71
Hi f,
"I would rather just buy the right mounts ... The car is a real 454 car so if I got the 69 big block mounts do you think they would work I really don't want to put washers in there"
I don't understand…
there aren't 'big block mounts', sb an bb mounts are the same,
and why wouldn't you buy the 70 mounts. Does your car have a 69 frame?
Regards,
Alan
Old Jul 31, 2017 | 04:08 PM
Dynra Rockets
Hi f,
I don't understand…
Regards,
Alan
Alan, they are the same as they bolt to the engine but as I understand it the factory BB mount that has the safety starting in 1970 are wider spaced at the frame stand (the tube the long shear bolt goes through). 2 3/8 vs 2 5/8. His picture supports that. Many aftermarket motor mounts have spacers welded to a common stamping to make up the difference when used with small block/early BB stands.
His 1970 car must have been made before the cutover to the wider stand and thus uses the earlier style 2 3/8 mount.
Forman, Order this
http://www.speedwaymotors.com/Rubber...0aAhokEALw_wcB
Old Jul 31, 2017 | 11:21 PM
forman's Avatar
forman
Forman, Order this
thank you
Old Aug 11, 2017 | 10:23 PM
forman's Avatar
forman
thank you
so i get the mounts and they are wrong ,,,, too thick and bring the motor to high in the cradle the fan hits the shroud thanks but no thanks im sending them back
Old Aug 11, 2017 | 11:38 PM
Brcmpbl's Avatar
Brcmpbl
I've had good luck with Corvette Central's mounts. Here is an article with links to parts: http://tech.corvettecentral.com/2011...148.1499775541
Old Aug 12, 2017 | 08:57 AM
Dynra Rockets
Adjust the shroud?
To Wrong motor mounts
